This Cybertruck needs a service centre visit, are panel gaps future norm?
Discussion in 'Cybertruck' started by CertLive, Sep 22, 2020.
  1. CertLive
    CertLive Member
    United Kindom
    The year is 2022 and still no one used a spirit level.
  2. HankLloydRight
    HankLloydRight No Roads
    Connecticut
    It's a one-off prototype. Let's see how well you can do hand manipulating bullet-proof 302 stainless steel into perfect panel alignment.
    • Like x 4
  3. Xenoilphobe
    Xenoilphobe Active Member
    Fairfax County, Virginia
    If you want to see panel gaps, you should see my FJ...
  4. glide
    glide Active Member
    Looks better than most MY’s I’ve seen.
    • Funny x 2
  5. CyberGus
    CyberGus Not Just a Member
    Austin, TX
    I'll take delivery on that right now.
    • Like x 12
  6. Watts_Up
    Watts_Up Active Member
    In a galaxy far, far away
    It seems made of stainless steel, look very nice !!!
    I just wonder if there would not be too much reflection at night from other cars high beam?
  7. jboy210
    jboy210 Supporting Member
    Northern California
    Worried about panel gaps on a truck? What is going to happen the first time you take a rock or bush.
    • Like x 4
  8. KBowden
    KBowden Member
    Socorro NM
    Considering its skin is nearly as thick at the wall thickness of the tubes I used for the roll cage on my rock crawler... hitting a bush ... Nothing. Hitting a rock or a tree... depends on how hard
  9. jboy210
    Northern California
    Still going to get scratches when something scrapes or rocks get thrown up from the tires. Someone worrying about panel gaps would likely be worried about scratches.
    Personally, I think the scratches and dings are part of owning a truck. They are meant for work, having fun, etc. And scratches and dings just add to the patina of a truck.
    I can't wait to see the complaints in the forums about the noise the tires make.
  10. Xenoilphobe
    #10 Xenoilphobe, Sep 25, 2020
    • Informative x 2
  11. Xenoilphobe
    I can't wait either... to be rolling down the road with that awesome whine....
  12. KBowden
    KBowden Member
    Socorro NM
    Especially with how quiet the rest of the truck will be. I had those exact tires on my Jeep, they are pretty quiet, much quieter than the ones I have on it now, but when there is very little other noise the tires will be very noticeable.
    Rocks thrown up from the tires wont have any effect on the stainless, they don't even effect my rock sliders and those are mild steel. It has taken significant contact to scratch them, and I have only been able to dent them when a tire slipped off of a rock and dropped it full force onto a rock.
  13. jboy210
    Northern California
    Once you get a CyberTruck, the rock may come out on the losing end of a future such collision.;)
  14. coleAK
    coleAK Member
    Alaska
    I don’t see any body gaps just some very pointless large rims... with MT tires... and not much sidewall... all for show... how about 17” instead of 22’s... no one will be talking that off road, and it will be a self setting anchor in the sand.
  15. coleAK
    coleAK Member
    Alaska
    You may have had similar tires but not the exact same, unless you were doing RnD for Goodyear, they are prototypes. And the will be loud especially when worn <50% like all MT/AT tires.
  16. Xenoilphobe
    SPECULATION: 35 x 12.5 x 18s I believe.
  17. coleAK
    coleAK Member
    Alaska
    No way that is close to a 8.5” sidewall in the picture. 35’s on 18’s look like they are all tire. I had 34’s on 17’s on my 80, see the pic below to see what a 8.5” sidewall looks like. Think about it. If it was the sidewall from both sides would be about the same size as the rim. No way those are <20 and if they are 35’s I’d bet they are 22” rims (or larger) with a at most a 6.5” sidewall.
  18. zecar
    zecar Member
    New York/Chicago
    By the time Cybertruck ships Tesla will have convinced you that panel gaps are manly. Or womanly. Whatever keeps you from complaining.
    If you identify as a They, perhaps complaining will be allowed. Not sure.
    • Disagree x 1
  19. LionXng
    LionXng Member
    Virginia
    Pop on some side mirrors and I would too!
  20. CertLive
    CertLive Member
    United Kindom
    I do hope to see them on UK roads someday. The Cybertruck looks like nothing else. Trucks that are faster than a McLaren F1 how things have improved!
