Were you given a choice of which phone cables were included, or is it a case of "you get these two and if you don't like it, buy the ones you need"?
Yes they give you one iPhone cable and one USBC cable. The rep installed the one I wanted when I picked up my Model 3.
I’ll probably just order the official one because I know it’ll be right, but thanks!The cables are ~14.5" long with a straight USB on one end and a 90º turn on the end with the Lighting or USBC connector.
You may want to hold off until you get your car @run-the-joules -- the official Tesla-provided lightning cord sits too low to connect with my iPhone X (with a relatively thin case). I ended up installing an Anker cord instead and just threading it through. Doesn't sit as flush but at least it connects.
Ruh roh. I don’t use a case but still, slightly worrisome.You may want to hold off until you get your car @run-the-joules -- the official Tesla-provided lightning cord sits too low to connect with my iPhone X (with a relatively thin case). I ended up installing an Anker cord instead and just threading it through. Doesn't sit as flush but at least it connects.
Do they not give you the option of getting a micro usb cable?Yes they give you one iPhone cable and one USBC cable. The rep installed the one I wanted when I picked up my Model 3.
There wasn't one with the car when we picked it up. There were just the two cables in a bag. You might be able to get one if you ask when you pick up the car. I also see that you can order a micro USB cable here: Model 3 Phone Charging CableDo they not give you the option of getting a micro usb cable?
Would a 12" cable reach?The cables are ~14.5" long with a straight USB on one end and a 90º turn on the end with the Lighting or USBC connector.
I would need two USB C ones, but I'll wait to see what my options are whenever the day comes
I need a micro connector, does anyone know if they have the cables at the delivery centers for purchase? I'm holding out for dual motors so I've got plenty of time to order and receive one in the mail but I'm sure I'll forget it on delivery day and leave it at home.
I think this is the way to go. At least for those that need a micro USB connector. I did a lot of searching on Amazon for something that would work and based on what I found none of the right angle cables have a long enough end on it to reach where the phone would sit. The other good thing about the official micro USB cable is that it has a reversible end so it will work for both the driver and passenger installations.I’ll probably just order the official one because I know it’ll be right, but thanks!
