Thoughts on Solid Black vs. Obsidian Black Metallic??? HELP
Discussion in 'Model S: Interior & Exterior' started by CTgigawatt, Nov 13, 2016.
  1. CTgigawatt
    CTgigawatt 2017 Model S 60D
    Connecticut
    Hi All,
    Anyone have any thoughts on the solid non-metallic black, vs the metallic black paint? Anyone have any experience with pros and cons of either?
    Thanks!
  2. JClu
    JClu Member
    Chicago
    Solid black is, well, plain black like the plain white (not available anymore). Obsidian black supposedly has these shiny metallic specks in the black that shines in bright sunlight.
    I was debating between the two as well. Then I went with the blue...which is what I wanted in the first place. Love my blue. :cool:
  3. JClu
    JClu Member
    Chicago
  4. Dr. Smoke
    Dr. Smoke My former name was Edmond. Before that, Quantum`.
    Edmonds, Washington
    I have the solid black and had to tart it up with brushed black wrap. You want the Obsidian.
  5. virtualsmack
    virtualsmack Member
    SoCal
    i have midnight silver. it has the similar specs as the metallic black. some things i learned:
    - metallic is that it is harder to match paint color in case of accident or painting needs. some retailers have mentioned this to me so i don't know this first hand.
    - the plain black is supposedly darker and more pure black while the metallic has more shine to it or can look lighter when lights hit it, due to the flakes. better or worse is subjective but the most unbiased way to put it is that metallic has some interest to it whereas plain black is more what you would expect from the color black.
    hope that makes sense. i debated both blacks and if i had to pick id go w the plain as i didn't think the extra $ was worth having flakes. ultimately wanted something grayish.
  6. JPP
    JPP Active Member
    SF Bay Area, CA
    My wife's S is one of the first with the Obsidian--really lovely color. Very different look in daylight, artificial light and at night.
  7. CTgigawatt
    Connecticut
    I guess i'm leaning towards solid then, because I really want it to be that really rich glossy black esp at night, and i plan on trying to keep it cleaned / waxed often..
  8. Jean-Claude
    Jean-Claude Local Vendor - Southeast
    Atlanta, GA.
    Get metallic paint if you want something that is easier to keep up. The metallic does a fine job naturally masking fine marring in the clear coat.
  9. HebrHmr
    HebrHmr Member
    Florida
    Solid + hydrophobic coating...almost did this myself but thought red wheels would look weird since I'm going black/red.
  10. shokunin
    shokunin P85 & M3
    Irvine, CA
    I'd go obsidian unless you get the front end wrapped in PPF. Any imperfections in the clear coat show up as white spots, just like swirls are easiest to see in black due to them reflecting back as whitish. Any minor chips, scratches, water spots, bug splatters and stuff just reflect off the plain black. Both my S's have plain black roofs and you can clearly see any imperfections and spots.
    Don't have personal experience with Obsidian but typically metallic will sort of mask some of those imperfections. However, obsidian doesn't look as "deep black" as plain black.
  11. JClu
    JClu Member
    Chicago
    All these suggestions about which type of black paint to get are, well, personal opinions. Color of the car is a pretty personal choice, and many people have VERY strong opinions one way or the other. Very similar to this thread's discussions for black, I'm amusingly following another active thread about WHITE colors. Again, personal choices. :p
  12. cassiri
    cassiri Member
    I looked at both and chose solid black. If you are someone that will keep it clean and like the deep shine it is better IMO. The obsidian looks like it has dust on it which is good for hiding actual dirt, but will never have the glossy shine. I would highly recommend a second mortgage and get it completely wrapped with Expel ultimate. very glad i did but an expensive pill to swallow. After a year and half I have no swirl or scratch marks and frequently just wipe the car down. I also just did a little DIY 3M gloss black chrome delete project. It isn't perfect, but cost me $70 in material instead of the $1k i was quoted. I don't think black out would look as good with obsidian. IMG_0367.JPG
  13. Xenoilphobe
    Xenoilphobe Active Member
    Fairfax County, Virginia
    i could not agree more
