three of five meters type 2 cable?
Discussion in 'Model S: Battery & Charging' started by Hybris, Feb 25, 2014.
  1. Hybris
    Hybris Member
    Sweden
    what lenght do you think is the best for a type 2 cable? 3 or 5 meters?
  2. hcsharp
    hcsharp Active Member
    Vermont
    5 meters for sure. It's not much more and will get you out of a bind quite often. You can't always park right next to the charging station; sometimes they are ICE'd. Many times you have to pull in forwards so the charge port is a long way from the station.
  3. jontracey
    jontracey Member
    United Kingdom
    5 meters allows some extra "wiggle" room, good if you have to go around an. ICE car blocking the charger
  4. Eberhard
    Eberhard #421 Model S #S32
    Germany
    none of them. the minimum is 7m to connect to a wallbox in fron of your car. the car alon is 5m.
    i gave my 5m cable away for my 7m.
    an extra 3m would be fine, if you back your car in.
    lg
    eberhard
  5. VolkerP
    VolkerP EU Model S P-37
    Germany
    Owners report that 10m or even 12m of cable are necessary for that use case.
  6. amitb00
    amitb00 Member
    Miramar, FL
    What is this cable used for? Can you post a link to buy it? I am assuming I may need it as well.
  7. Hybris
    Hybris Member
    Sweden
    the cable is for using at public type 2 chargers. At home i have the red three phase adapter that I will evaluate before deciding on any wallbox or similar at home... So the original question is for a type 2 cable for public charging stations like ikea etc.
    Not sure type 2 is of any use in the US? its used a lot in Europe at public charging stations.
    Sounds like 5 meters is the way to go for that need...
  8. amitb00
    amitb00 Member
    Miramar, FL
    Thanks Hybris.
