Three Teslas for sale in Bellevue, WA
NEWDL
R#350 R#1323 Sig23(traded) 8136, RWD LR 3, P3D
Jan 5, 2009
489
4
NE OHIO
#553? With as much track time (Drag) as this car has seen... and been attached to all kinds of chargers approved and non-approved.... I would call this one a risk...
Why is he selling?
DaveD
EVs Kick Gas!
Aug 18, 2007
642
242
Redmond, WA
Drag racing a Roadster is a lot different than drag racing an ICE car. Drag racing it puts little more stress on it than a hard launch from a stop light. The torque output of the electric motor is totally controlled by the computer(s) in between the accelerator pedal sensor and the motor drive IGBT's. If it can't handle a straight accelerated run down a smooth pavement to reach 100mph, it really has no business being out on public streets! On the other hand, an ICE car, what with revving the engine to redline (or past), popping the clutch ... yeah, for sure I'd be leery of buying that.
It's never been attached to any "charger" except for the one that's built into it, which is a part of the PEM. It has been attached to charging stations (aka Connectors, in Tesla parlance), but those are nothing more than glorified extension cords, with user safety features built into them. Even the pilot signal is designed to protect the car under normal conditions. Any damage to the Roadster from using "non-approved" charging stations is much more likely to come from whatever voltage spikes that came off of the power grid that the charging station was attached to. That sort of damage would have happened even if a Tesla connector were used.
scott451
KWH-PWR#1349Sprt,S Sig#96
Apr 2, 2009
258
2
Palo Alto
Actually, the pilot is designed to protect the "charger" not the car (or PEM). The pilot tells the car "do not draw more than XX amps". So the car can draw any amount of current up to the limit signaled in pilot. The external "chargers" are, as you say, glorified [GFI] extension cords with a built in circuit breaker that pops if your car draws too much current.
NEWDL
Jan 5, 2009
489
4
NE OHIO
Even with your defensive "expert" descriptions and personal opinions... My concerns still stand. Just because you live near him and may or may not have done business with the owner/previous owner does not mean that the car is more risky of a purchase than one that has not has the previous things mentioned done to it. END OF STORY.
