Nosken
After all that we both loved everything else about the 3 so much we will be taking delivery of one as soon as we are able to configure with 18" wheels and putting Unplugged Performance mild version springs on plus I will change the tires to Michelin premier a/s in 245/45/18 as the are rated for 1764 lbs. ( this tire is only 0.3" taller overall ) I will be able to run the air pressure 3 lbs. less while maintaining the same weight rating so if 42 psi is acceptable for stock Ill run 39 psi, I believe this combo will result in a much improved ride while maintaining near stock ride height and looks
Would such "low" tire pressure trigger TPMS warnings constantly?
