Throw the Ez-Tag transponder in the glove box
JasJ
421
485
Houston, TX
I went into the Houston EZ-Tag store to get a tag to put on the windshield next to the rear view mirror and the lady at the counter insisted that I take the larger 'plate' transponder and put it in my glovebox.
Anyone else in the Houston area doing this and does it work? I don't really want to place on the license plate, but have no problem with a glovebox location.
Thoughts?
kort677
Banned
Sep 17, 2015
4,801
2,241
florida.
just be aware that every one of these toll collection units and systems can work differently.
here in FLA as long as the car is registered with the tag account the photo system should work. The EZ PASS system in the north east does not work this way.
BrettS
2,108
2,511
Orlando, FL
In florida we don't have front plates, but they sent me a tag like that for my Model S. If you have a pre-facelift car you can take the nose cone off and just zip tie it to the metal bracket behind the nose cone. That's what I did with mine and what the previous owner did with his.
AndrewTX
192
156
Houston, Texas
Thoughts?
When I registered by MS with the toll road authority they tried to give me one of those transponders but I declined. I use the normal tag just to the right of the rear view mirror mount and it seems to work fine.
JMG
386
263
NE Texas
I still have no such tag anywhere on my car and they just match up the license plate for me. I keep the tag in the car in case I need to use it at the DFW airport.
BerTX
3,505
3,559
Texas/Washington
Thoughts?
So are they saying this transponder actually WORKS in the glove box? That's what t sounds like -- why would they give you a plate transponder if they are just relying on plate recognition like others here seem to be assuming? The regular one would fit in the glove box better...
sgmorton
73
51
Baytown,Tx
The EzTag store locations all have a tester in their parking lot. I think I'd test it before I just threw it in the glove box and forgot about it. I know there are some places (Not HCTRA) that charge more for plate reads than eztag reads. Also with the way the windshields are on Teslas I would bet it blocks transponders in the glove box. I know placement on a MS is sensitive. Mine is in the upper cornet on the passenger side.
larmor
2,171
5,457
Westlake, TX
Using fastrak in CA, i wasn't keen on putting the transponder on the MX windshield... So kept it in the driver's door pocket. Beeps pretty reliably and gets picked up....
David99
4,850
7,021
Brea, Orange County
Not sure if it's the same, but in CA you just register your tag and then tag the transponder and "throw it in the glovebox" because the cameras will get your tag each time.
In CA the law specifically says you need to have your transponder mounted on the windshield. Only exceptions are license plate mounted transponders.
JasJ
421
485
Houston, TX
Wish I had known that.. what does the tester look like?
As I have temp plates, I'll test tomorrow when I drive down a tag only road
I'll look online to see if the transponder is picked up. ;)
sgmorton
73
51
Baytown,Tx
There is a reader on pole at the one on the southeast BW8 location but I think they all have them. It's just a lane you drive down and the light lets you know it worked.
AndrewTX
192
156
Houston, Texas
There's always one in the parking lot somewhere. Ask one of the employees if you don't see signs. I tested a couple of different windshield locations on my MS before I left.
Reactions: SW2Fiddler
cgiGuy
1,500
1,082
Everywhere, Nowhere
Maybe.. but I've been using Bay Area FasTrack for a year with my plate "mountable" transponder mounted under the nosecone and each time it only picks up the license plate number. They charge just the same and have never indicated that this is a problem.
Reactions: David99
David99
4,850
7,021
Brea, Orange County
A little OT but I noticed my transponder beeping when I drive into LAX airport. There is no toll and you don't need a transponder to drive there, but they use the device to track when you enter and leave the area. Big brother is watching you.
SW2Fiddler
We Are Cognitive Dissidents
Mar 19, 2014
2,362
3,246
Houston TX
on the plates, they have a locking screw, and it really doesnt bother me too much since I already have the front plate mounted.
This.
I tried inside the nose cone, and since that didn't read satisfactorily (in their "Test Your Tag" lane in the parking lot), I had Tesla Service move it to the front plate.
i.e. Do The Obvious Thing :)
