Tighten your valve stems!
Discussion in 'Roadster 2008-2012' started by n2mb_racing, May 17, 2015.
Tags:
  1. n2mb_racing
    n2mb_racing Active Member
    durham, NC
    I went for a drive yesterday and got stuck on the side of the road with a flat tire. Luckily, I didn't use the tire slime. I called AAA and they inflated the tire again. We found a leak coming from the valve stem. We tightened up the nut holding the valve stem (and TPMS, I assume) to the rim and the leak went away.
    Moral of the story, check those valve stem nuts and carry a small tire pump! The geniuses that installed my new tires didn't tighten them, I assume.
    I also found out that my rear TPMS sensors are swapped. The tire guys also managed to screw that up. Is there a way to retrain the TPMS system so that it gets the right sensors in the right places?
  2. Doug_G
    Doug_G Lead Moderator
    Ottawa, Canada
    You have to use a special TPMS tool to reset the sensors. They used to sell the tools (not cheap), but now you pretty much have to go to a service center.
  3. Panicopticon
    Panicopticon Member
    Syracuse, NY, USA
    RST-184-A
    Tesla part number: 1013547-00-A
    Description: TOOL, TPMS, ROADSTER and MODEL S
    Status: Distribution
  4. n2mb_racing
    durham, NC
    Can they reset the TPMS sensors without unmounting the tire? If so, it seems like something I could ask them to do quickly next time I'm there.
  5. Doug_G
    Ottawa, Canada
    Yes, the process takes about 30 seconds.
