Dborn
Confirmed
Ok. Just got it after a reboot of my iPad. However, no option to charge from the grid. WE NEED THIS FOR CLOUDY DAYS HERE IN AUSTRALIA
We could use it in Colorado too. While we have over 300 days of sunshine per year, sometimes we have weeks of snow in the winter. Being able to charge from the grid would help us prepare for a blizzard and let us continue as normal if the grid goes down due to have snow.Ok. Just got it after a reboot of my iPad. However, no option to charge from the grid. WE NEED THIS FOR CLOUDY DAYS HERE IN AUSTRALIA
According to a recent post on whirlpool.net.au, it looks like charging from the grid is available in Australia with the new TOU capability.
Hopefully, it'll "learn" to charge a bit more before 2pm. I'm happy to see the progress, though, particularly as our PWs (still lacking the TBC feature) have been spending most of their time between 80% and 100% charge. This time of year, I'd prefer to cycle them at lower charge levels for more optimal battery longevity, and exporting more to the grid would facilitate this. (I'd still like to have a "max target charge" parameter, though.)The problem is that it did not take the opportunity to charge to full before 2pm, so it ended at ~56% IIRC, when I had the Reserve set to 50%. Then today, starting from a low SOC, it still didn't take all the energy it could before the Peak period started.
I have it set on Cost Saving.miimura,
Were you using "Balanced" or "Cost Saving" Time Based Control mode?
I had not seen that information before. Did they update those pages recently? In any case, the way I read it, during the shoulder period, Cost Saving should behave like Self-Powered. My system clearly is not doing that. For a period in the morning, it is charging from All Solar, then it charges at some level less than Excess Solar, leading to significant export. On weekdays, my nominal value of solar is equal to the shoulder rate since I don't have any generation during Off-Peak. It doesn't make sense to cycle the batteries more during the shoulder period with Net Metering and it doesn't matter when during the shoulder period that you export. So, to me the logical thing to do during the shoulder period is charge with All Solar until the battery reaches some relative SOC between the Reserve and 100%, then charge from Excess Solar until full, then export Excess Solar. This is really not rocket science and trying to make it "Smart" is just going to lead to customer disappointment in certain situations. However, I will grant that people who have low feed-in tariffs would benefit from it being a little more Smart like charging from the grid when the weather forecast indicates low solar generation for the following day.I wonder if "Balanced" would be better? From the table Powerwall Modes of Operation with Solar it seems that the Shoulder times cancel each other out, as they are both on charging and discharging priority.
That's exactly what I did and it works fine.Or eliminate your Shoulder in the morning so it charges up to the Peak.
It just appeared in the app. I don't think there's anything an end user can do to get it sooner. Don't be too jealous. I turned off TBC this afternoon so that I would be able to maintain my 50% reserve for the storm coming through starting tonight. My solar generation today was too low to allow it to export during Peak hours, so I put it on Self-Powered and now that Peak just ended, I'm at 53%.@miimura, who did you bribe to enable the feature? I think my system was installed before yours. We're both PG&E/Silicon Valley Clean Energy. I am still on E-6 until my experimental sub-meter pilot expires then I will switch the whole house to EV-A.
arnold
