vcor
Tech Specialist
Perhaps another way to look at it is how the frequency of charging affects longevity. Unlike older battery technologies, Lithium-Ion cells are rated with a total number of charge cycles. Let's say the battery is specified for 1000 charge cycles. This is from 100% to 0% and 0% to 100% (the SOC thresholds are specified by the battery manufacturer, and 0% is not 0V which would kill the cells). In simple terms, if you charge from 100% to 50% then 50% to 100%, that's considered a 1/2 charge cycle, and you can do this for 2000 cycles. Charge from 60% to 50% then 50% to 60% and you can do this for 10,000 cycles.
So if you have a small battery that must be charged and discharged frequently in a PHEV, you need to set more limits to get more cycle life.
There are other factors for longevity, but hopefully, it makes better sense. As others point out, leaving SOC at 100% or 0% for a longer period of time is bad too, and should be done sparingly. Temperature is also quite important and the vehicle should regulate that as needed, or life is reduced.
I expect Tesla is quite a bit ahead of everyone else in managing the battery for longevity, but others are catching up. Then again, so many new EVs and companies producing EVs are new to the game, I'm not as sure they got it right. It may take a few iterations, as Tesla did with the 2008 Roadster.
