No Feed-in-Tariff export meter here (well ... not in my home, maybe in some homes in UK), so Utility assumed that 50% is exported, and pays accordingly. Haven't looked at whether using a Battery voids that ... probably does. Not installed Powerwall as not quite ticking all the boxes I need yet ...
... we have max solar panels (forgotten the actual output, but its 16 panels) for single-phase. To be able to "export more" I would have to upgrade to 3-Phase, which in UK because of monopoly is an arm-and-leg to install, even if everything they need is at the nearest pole ... (it is possible to ask the Utility if my property would be allowed to export more - presumably if the local area infrastructure would support that then they would be happy, but I haven't asked)
My plan is to install more solar and feed that into Powerwall, so only my legacy 16-panels exports to grid (and gets the FiT subsidy payment). I'd like to reduce my usage (car mostly charged at work) but we have a lot of work-based computer/server stuff running here
hence I would like to install more self-generation
Also considering if I could install Wind instead/in-addition. Its basically open farmland towards the prevailing wind, but we have some trees around which, last time I enquired, would cause too much wind turbulence to be much good for generation. I have a tower and logging anemometer, which has been lying on the deck for ... Ahem! ... "some years" ... which I really need to get mounted to start logging how good my wind is
basically I need to get off my backside and get on with it ...
... but I wonder if you folks States-side who have restriction on Federal + Local subsidies could have two powerwalls, and only charge one of them for ToU in order not to fall foul of the rules-and-regulations? Some cost involved of course ...
