Roll both front windows down and drive slowly over an uneven surface with little bumps or dips. Could run over small pieces of plywood or something if you need to make an uneven surface. If you have the issue, you will hear a noise that sounds like an old, rusty box spring mattress creaking.How best to test for this?
Mobile Service inspected vehicle and said this repair had to be done at service center. We have new service center opening in our city in July. The alternative is to take a 3 hour road trip to the next nearest service center.My 2019 M3 SR+ at only 33,000 km (~20,000 mi) has a loud creaky front right ball joint - have a Mobile Service appointment soon to fix it.
I had my driver side FUCA replaced at 33k miles. My passenger side one is still good at 63k miles. If one of them starts making the noise again, I will probably replace them both with an aftermarket. I thought about installing grease zerks on them and taking pictures or measurements to share with people. But I only thought about doing that with the FUCAs off the car (once I've replaced them). The problem with doing this on the car is that you don't have a backup in case you mess something up. If you do try it, let us know how it goes. And it would be helpful to start a new thread about adding zerk fittings where you can share details, pictures, and/or video.I understand if someone was within warranty still or doesn't have the ability to do this. But has anyone else thought of added zerk fittings to the ball joints? This video shows ball joints that look very similar to the model 3 upper ball joints. If your out of warranty and they are still tight but just making noise, I'd be trying some zerks. Mine are still quite at 20k (rev g) and I'm thinking of adding zerks to prevent the issue. On the other hand, tesla could then deny warranty if they still went bad...
Just wanted to add that the reason why I would not drill and tap the ball joint with the FUCA on the car is because I would want to get rid of all the metal shavings/chips from the process. The best way is to disassemble the ball joint components and wash out everything.I had my driver side FUCA replaced at 33k miles. My passenger side one is still good at 63k miles. If one of them starts making the noise again, I will probably replace them both with an aftermarket. I thought about installing grease zerks on them and taking pictures or measurements to share with people. But I only thought about doing that with the FUCAs off the car (once I've replaced them). The problem with doing this on the car is that you don't have a backup in case you mess something up. If you do try it, let us know how it goes. And it would be helpful to start a new thread about adding zerk fittings where you can share details, pictures, and/or video.
Resealing the joint would imply that they remove the rubber boot (and the spring clips that clamp it on) and re-lube the joint. Then replace the rubber boot and spring clips. You can buy replacement rubber boots to fit a few ball joint sizes at your local auto parts. They are usually for replacing a torn boot.Agreed if these were the type of ball joints that you could actually take apart and rebuild. Pretty sure these are non serviceable and non rebuildable ball joints. Best you could do is drill and tap them off the car where you might be able clean and spray out the area a bit better before installing the zerk. Definitely agree you want those chips and shavings out.
Does anybody know what this "sealing" of the control arm is suppose to do? And how it could possibly be lubricating the ball and socket area thats making the noise?
I just came across this link that says something else about the sealing. To prevent water ingress.Resealing the joint would imply that they remove the rubber boot (and the spring clips that clamp it on) and re-lube the joint. Then replace the rubber boot and spring clips. You can buy replacement rubber boots to fit a few ball joint sizes at your local auto parts. They are usually for replacing a torn boot.
Wow. The 4 wheel alignment cost after the potentially replacing or greasing the joint, makes me nervous at the likely cost of yet another issue where I’m averaging $800 in repairs the last 4 months. June was a quiet enjoyable month but July spiked my average again with $1700 compressor repair.It probably depends on a lot of things, but I'd say minimum of 2 hours. It took them 7 hours to do mine. Keep in mind that they also do a four wheel alignment after replacing it.
anyone here with a failed upper control arm with a "G" revision? I did see plenty of "F" failures but from reading through this "G" was used in assembly from spring / summer 2019 to early 2020 before they moved on to "H" and later "J" revision
Here is EG solution. Only $100 and if you’re DIY savvy. Good solution for people with aftermarket parts.
Model 3/Y Noisey Ball Joint Repair Kit
Does your Model 3/Y make a squeaking noise when you turn the steering wheel at slow speeds or going over bumps. The ball joint in the front upper control arm is most likely the issue. This kit consists of all the parts and tools to drill and tap the top of the ball joint to install a grease...shop.electrifiedgarage.com
