Timed charging not working on J1772
Discussion in 'Roadster: Technical' started by asgard, Sep 12, 2013.
  1. asgard
    asgard Member
    The timed charging on my 1.5 roadster is not working when plugged into a J1772 using the Tesla adapter. It does nothing.
    I also tried it with Henry's CAN - same result. However, it works when using the backup 110V cable.
    Charging immediately when plugged into J1772 works fine.
    Is this normal?
    Thanks!
  2. Lloyd
    Lloyd Well-Known Member
    San Luis Obispo, CA
    You have to set the delayed time to charge at each location you charge.
  3. asgard
    asgard Member
    I tried that and reset it at each location but it just skips over the time and does nothing.
