Haven't seen this tip elsewhere but I've discovered it over the last couple weeks. Took me a bit to figure out what was going on. Neat to have access to without third party methods/tools.
Prerequisites:
My battery at the time of writing has been sitting all night in what was probably about 2°C (36°F), and reports 99%. On a colder -5°C (23°F) night, I had it report 97%. Unfortunately this is my memory so the overnight temperature is a rough guess from memory.
Note that the snowflake icon does not need to be present before it reports a lower state of charge!
I could be entirely wrong about what this is showing, but it certainly seems correlated to battery temperature.
Prerequisites:
- The last driver profile active when exiting the car must have battery capacity in percentage, not rated range.
- You need to wake the car to check this, as far as I know.
- This works on the Android app, not sure about iOS.
- Click on the battery icon, or the "Charging" button.
- Drag the limit slider all the way to the right. Note the battery percentage on the left side of the battery.
- If the shown amount is 99%, you know very roughly that 1% is "locked out" due to cold. If 97%, then 3%, and so on.
