I was experiencing overnight battery drain from my Model X, and found the reason for the issue.
I usually put my key fob next to the door to the garage, and that was the cause of the problem.
After locating the key fob way from the door (10ft) the problem has disappeared.
If you are experiencing the same problem, just check where you put the key fob.
P.S. I saw a number of threads related to this issue, but haven't found this solution (Please correct me if I am wrong)
