Tire Changes at what miles?
Discussion in 'Model S' started by Maximilien, Aug 20, 2018.
  1. Maximilien
    Maximilien Member
    Irvine, CA
    I know it varies based on the driver's driving style...
    But at what miles did you guys change your tires? I think I heard as high as 43,000 Miles before. I am already hearing squeaking sound when I make a turn. It is about time for the maintenance for 2nd year anyway.
    Can any Tesla veteran(50K+ Miles) drivers share when you changed them?
  2. tpham07
    tpham07 Active Member
    Rhode Island
    im at 35.5k miles and still 4/32". nearing the end though.
  3. Barry
    Barry Active Member
    Colorado
    I needed need tires (orig MXM4s) at 27K. Got an $80 credit per tire with Michelin's tread wear warranty (not available through Tesla, but only via authorized dealers).
  4. ucmndd
    ucmndd Active Member
    I get a about 30k on MXM4s.
  5. Langhorne
    Langhorne Member
    PA
    I am at 31k miles, and will need a new set soon. I am thinking of stretching it another 2k miles or so.
  6. Evil Twin
    Evil Twin Member
    Los Angeles
    Get a Lincoln penny...it will tell you all you need to know about when to change your tires.
  7. Evil Twin
    Evil Twin Member
    Los Angeles
  8. BerTX
    BerTX Supporting Member
    Texas/Washington
    I changed my Goodyears at 36K. They would have lasted longer except for lots of highway miles at lowered suspension height wore down the inside of the rear tires. I turned off lowering.
    • Informative x 2
  9. Maximilien
    Maximilien Member
    Irvine, CA
    I checked it with the coin and it seems my tires are in the "tires are fine."
    I am approaching near the 27K miles.
    But when I take a sorta sharp turn, the tires make skidding sounds. Is this normal? I didn't hear them before and was worried whether I should change the tires.
  10. M423
    M423 Member
    Miami, FL
    Changed my Goodyear’s around 34k , went with Pirelli cinturato All season plus , 70k thread life, will see
  11. cytranic
    cytranic Member
    FL
    Every 8k. 21 inch conties ;(
  12. Evil Twin
    Evil Twin Member
    Los Angeles
    Your tires will certainly make different "noises" as it runs through it's lifetime. Your very powerful car can stand to get new tires before the "official" wear date.
  13. brkaus
    brkaus Well-Known Member
    Austin, TX
    I’m at 27k and think I have about 3k left on the orig Goodyear tires.
  14. Maximilien
    Maximilien Member
    Irvine, CA
    I think I am in the same boat. My guess is that I have about 2000-3000 miles before I change them.
    But those skidding sounds from U turn does gives me the alert.
  15. ahkahn
    ahkahn Active Member
    Chicagoland
    Same here. My Goodyears had about 37k, and just put the Cinturato's on.
  16. TSLATed
    TSLATed Member
    Orlando
    I changed my Goodyear Eagle Touring tires at 31k, but could have safely driven about 3-4k more miles.
  17. NikeWings
    NikeWings Active Member
    Crazy......replaced my ContiSilents juts under 27K........and they still rode better than new michelins.
    It's a great tire and better than 9K.
  18. Kacey Green
    Kacey Green Member
    Charleston, South Carolina, United States
    The rears go about twice as frequently as the fronts on my 2016 Model S 90D with 19"
  19. NikeWings
    Rotate those.....they might live longer?
  20. Kacey Green
    Kacey Green Member
    I rotate the rear to the front when I replace the fronts. If I catch it I roll the fronts to the back when they're the ones with more meat
