Tire FYI
Discussion in 'Model X' started by rdalcanto, May 29, 2016.
Tags:
  1. rdalcanto
    rdalcanto Active Member
    Salt Lake City
    Got in the X today and had a low pressure warning in right rear. Stopped and found a screw in the center of the tire after less than 600 miles. Went to the gas station/shop near our house for a repair. They took the tire off and initially refused to fix the tire because there is a foam ring glued to the center of the tire. After convincing them it was for sound deadening and not structural in any way, they agreed to fix it. They cut away a section of foam to get to the rubber. But, the tar like glue keeping the foam in place is awful - thick, sticky, and hard to remove. Eventually they were able to get it clean enough to chemically bond the patch and seal the tire. Also, they didn't realize at first that the lug nuts have plastic covers over them that look like real nuts, so they couldn't find a socket that would work. Once I told them, them slipped the covers off, revealing the real smaller lug nuts underneath, and they were able to get the wheel off no problem.
    • Informative x 14
  2. jerry33
    Texas
    I would find a more qualified place to work on my tires in the future.
    • Like x 5
  3. Husamia
    Husamia Member
    Falmouth, KY
    thanks for the info. Can you take pictures of the lug nuts?
  4. CaliX
    CaliX Member
    Los Angeles
    what is the brand and type I have been looking for those. Can you post a picture of the outside of the tire? Is there a product number on it?
    Thank you!
  5. beantobe
    beantobe Member
    Phoenix, AZ
    This ^^^
  6. rdalcanto
    Salt Lake City
    Yes. The gas station is fine for taking a tire off and putting a patch on a normal tire. I had no idea that our tires have the foam inside. These are the stock Continental All-Seasons that come on the 90D with the 20 inch standard wheels.
    • Informative x 2
  7. Saghost
    Saghost Well-Known Member
    Delaware
    Interesting. I'd read a year or two ago about tire companies planning to install sound deadening foam in some tire lines, but this is the first I'd heard that the X tires had it.
  8. CaliX
    CaliX Member
    Los Angeles
    How do we tell if ours has foam?
  9. jerry33
    Texas
    1. There may be some marking on the tire that indicates it.
    2. Go go the tire manufacturer's site and look up that model of tire. (be sure it's the exact same model because there may be quite a few "almost" models)
  10. Lyon
    Lyon 2016 S P100DL, 2016 X P90D
    Eugene, Oregon
    There's a logo on the side of the tire that says, "ContiSilent." Interestingly, I don't find them any quieter than the Nokian WRG3s I put on after we got a side wall puncture.
  11. paintpolisher
    paintpolisher Banned
    Atlanta, GA
    Since I have my X on the lift today, I pulled the wheels to apply OptiCoat Pro Plus to the barrels, rear of spokes and the faces.
    Here is the tool that will pull the plastic caps off: Amazon.com: Genuine Audi 8D0012244A Wheel Bolt Cap Removal Tool: Automotive
    (looks like Amazon made this an add on item)
    Here are pictures of the tool and how it works.
    Also picture of the "conti-silent" on the tire and a clean wheel. :)
    The lugnut is a 21mm and the torque for the lugnuts are 129 ft-lbs. (Just like the MS)
    IMG_2705.JPG IMG_2706.JPG IMG_2716.JPG IMG_2717.JPG IMG_2718.JPG IMG_2702.JPG
    • Informative x 8
  12. Mayhemm
    Mayhemm Model S P85+ "Lola"
    Saskatchewan, Canada
    Strangely, the lugnuts for my Model S seem to have changed size. I've been using a 21mm socket since I got the car in 2014, but that size now fits extremely tight (if it will go on at all) and will occasionally seize to the lug. This has happened with several lugnuts and I've tried using several different 21mm sockets in case one was damaged. What's going on? Needless to say, it makes any wheel-related maintenance a real chore. I'm also worried that I will damage the lugnuts one of these times.
  13. FlatSix911
    FlatSix911 Porsche 918 Hybrid
    Silicon Valley
    The OEM Tesla lug nuts have a stainless cap that distorts over time with wrench use.
    Pneumatic wrenches are especially bad for accelerated lug wear and size distortion.
    I ended up replacing all of my lug nuts with chrome vanadium steel ... problem solved :cool:
    • Informative x 5
  14. idoco
    idoco Member
    Outside Philly
    Can you share the manufacturer/item#/vendor for the aftermarket lug nuts?
  15. bikeandsail
    bikeandsail Member
    United States, NE Ohio
    My understanding is the caps should be removed before trying to loosen / tighten the lug nuts.
  16. FlatSix911
    Silicon Valley
    We are not talking about the plastic covers ... The OEM Tesla lug nuts have a stainless cap that distorts over time with wrench use.
  17. FlatSix911
    Silicon Valley
  18. Oceanwolf
    Oceanwolf Oceanwolf
    Morgan Hill, CA
    I just called America's tire in Gilroy. They said due to the tar (glue) the patches do not work. I need to find another place to fix my tire. I found a tiny nail on the rear tire.
  19. OzSimon
    OzSimon Member
    Gold Coast Australia
    Great thread, glad to learn all this. Does anyone know of a space saver spare wheel for the x?
  20. 3s-a-charm
    3s-a-charm Active Member
    Calgary, Canada
