Lloyd
Yes, I run a small airline and it is required in aircraft tires for that reason. Tires get hot on landing and taxi, then to -50C at altitude. Racing teams will always use Nitrogen because they can set their tire pressure prior to race and not have it adjust as the tires heat up. Race teams will see increases of 10 to 15 lbs + during race conditions, if nitrogen is not used, that affects the handling of the car.
If you drive your car hard and heat the tires up you will see and feel the difference. Other claimed benefits of less oxidation of the tire and wheel and less leakage through the tire are bogus. If you are just motoring on the roadway it is likely not worth the cost.
