Yes for MS but not for TPMS in general. I just found out my comment about Porsche or Roadster's TPMS can display actual pressure because tires on them won't see rotation is wrong. Costco intalled new front tires on my Cayman S reversed from the original postion last week. I got a warnning on TPSM display to reset the TPMS function. It worked fine after I did that. I wonder why Tesla could not implement a similar system. Is it because of the cost or what? The pressure display is a huge convenience over this dummy warning flag.
What is the wheel torque used?
Is that higher than average? My current car only needs 90 ft-lbs.I assume you mean lugnuts? 129 ft lbs or 175 N-m.
It that for 19", 21", or both?I assume you mean lugnuts? 129 ft lbs or 175 N-m.
Thanks. Nice to know, as I suspect many tire shops might not yet have the info.
I contacted Service regarding this problem and they "pulled the logs". It indicated an intermittent problem with the two front tire sensors. I'm scheduled to go in next week to have the sensor antennae tested and realigned, which is what they think the problem is.Had this warning yesterday. The warning was slowly flashing on the dashboard for a few minutes - then went on solid for a few minutes - and then turned off.
After stopping and waiting a few hours, checked the tire pressures - and all 4 tires were 45 to 45.5 pressure.
The warning did not re-appear in driving later in the day.
Car scheduled for service on Friday - and this will be on the list to check out.
[Running 44 software]
The only side effect would be if you had a real issue with one of the front tires and it wasn't reported. Unlikely, but possible. Because I'm leaving on a 1,000 mile road trip, I would like it handled before I leave.napabill, thanks for the update! Do you know if there's any side effect of not taking care of this till I go in for the annual service?! I have had the exact same symptoms as you do...
