New Y owner here. Cruising the display, I finally found the TPMS diagram. All the values for the four tires were blank. Is there some way to engage this feature? Isn't TPMS a stock feature? Still learning.
If the car has been idle for awhile, the TPMS values will go blank. When you wake up the car and drive around for a bit, the pressure values should fill in again.
Every time you park the Tesla vehicle the TPMS sensors go into sleep mode. It is maddening that you can't use the Tesla Model Y's TPMS sensors to help to set the tire pressure as the TPMS only remain active for a short time after parking.You only need to drive a short distance, less than 1/2 mile, before the TPMS sensors are activated.
