Tire pressure
Just wanted to share a bit of experience about tire pressure. Im running slightly lower tire pressure in the front tires over the rear tires. Around 2 psi, 41 over 43 and i find the car to be more maneuverable. It is less quick in turn but the car seems to rotate better. I honestly don’t know what is going on, but i feel there is less push to the front, compared to 45 front and rear.
So what are you guys tire pressure? Share your experience!
Tweaking balance with tire pressure is a thing, when you have no other options. Every tire has maximum grip at some pressure, above or below is less, so you probably gave the fronts more grip relative to the rears with that pressure.
Tesla’s tire pressure recommendation is all about efficiency, and not at all about performance, so the OP’s experience isn’t a surprise.
I’ve been running 38 PSI in mine - better ride quality, though certainly slightly lower efficiency.
I have about 42-43 PSI and I feel its a bit bouncy. What did you experience when yours were higher that made you try a lower PSI of 38?
Running around 37psi on my 18's for improved ride quality. I rarely max out battery range in normal driving, so I'd prefer to dial in a softer ride vs. maximum efficiency. Turn in is a little more sloppy, but my tires are not performance-oriented, so it doesn't concern me at all.
