Tire Pressure
Discussion in 'Model S' started by scottflys, Jan 23, 2017.
Tags:
  1. scottflys
    scottflys Member
    Argyle, TX
    I have a new MS with the 21's and a staggered setup.
    What is the best tire pressure to run them in?
    Thanks
  2. kort677
    kort677 Banned
    florida.
    what does the sticker in the door say?
    your answer will be found there
  3. ev-now
    ev-now Member
    Denver, CO
    I believe 42psi for the 21s, but mine are not staggered. As noted, door pillar should give specs for as delivered config.
  4. bishoppeak
    bishoppeak Member
    San Luis Obispo, CA
    My staggered setup wants 42psi.
  5. scottflys
    scottflys Member
    Argyle, TX
    Ok, I keep getting conflicting info.
    Called Tesla and was told 42 in the fronts and 40 in the rears. They were suppose to put a sticker on the car but online says 40 all around if you have the 21s and staggered setup with the Air Suspension, which is what I haven and bishoppeak says 42 all around.
    Mmmm
  6. bishoppeak
    bishoppeak Member
    San Luis Obispo, CA
  7. scottflys
    scottflys Member
    Argyle, TX
    Thanks a bunch, I have the 75D, same color but the Grey Wheels, do you have the Air Suspension? I have it and found a Tesla site that said 40/42 if you have that option.
  8. scottflys
    scottflys Member
    Argyle, TX
    Here is my Sticker, I didn't notice it before since there was one for the 19s as well.
  9. bishoppeak
    bishoppeak Member
    San Luis Obispo, CA
    I have the air suspension. Perhaps your smaller motors and battery make for less weight and hence, lower tire pressure. I'd go with what is on your sticker.
