No, and neither does the Tesla one.
If your car has tires with sound-deadening foam, you're better off carrying a tire plug kit and separate compressor that runs off the 12v port. You can get a tire plug kit at Walmart, auto parts stores, or Amazon. They range from $10 (sufficient) to $35 (deluxe). You can get a decent compressor on Amazon for around $30-$35, just make sure you check the specs that it doesn't pull more than 15 amps max or you'll trip the protection circuit on the 12v port in the car.
