Tire Repair Kit?
Discussion in 'Model 3' started by Smitty79, Aug 14, 2019.
  1. KenC
    KenC Active Member
    Maine
    TO = Tesla Ocoustic.
    Honestly, I have no idea, but that's their symbol for Tesla-specific tires, probably Tesla Original Equipment.
  2. Nels
    Nels Member
    Florida
    So, is the consensus that the Tesla "Model S/X/3 Tire Repair Kit" doesn't work on the 18" aeros?
  3. KenC
    KenC Active Member
    Maine
    Yes, a slime kit won't work on tires with acoustic foam inside.
  4. jebinc
    jebinc M3 LR AWD w/FSD and white premium interior
    Seattle, WA
    It will work, but will require the likely replacement of tire and TPMS sensor. :eek: The compressor will always work. Even with a nail in the tire, just pump it up and drive to a tire store. ;) No slime required. You can also get a plug kit as well, if you so chose. :)
  5. tvad
    tvad Member
    The problem with slime and acoustic foam tires is the slime gets absorbed by the open cell acoustic foam and does not reach the actual puncture, therefore it cannot seal the hole.
    So, I respectively disagree with the opinion that slime (or similar sealant) will work on acoustic foam tires.
  6. jebinc
    Seattle, WA
    No worries. Others have reported it does work, so there's that. It could be a hit or miss kind of thing, given the location of the puncture. I won't be using the slime myself, but rather one of the other tow methods I already described.
  7. tvad
    tvad Member
    You aren't on board with the ModernSpare kit idea?
  8. jebinc
    Seattle, WA
    I purchased the 4000# scissor jack that came with that kit, a high end plug kit, and the Tesla compressor (and slime). I didn't want to take away precious cargo space with a spare tire - especially if I threw in the spare for longer road trips (where I would likely need the cargo space, etc.)
  9. tvad
    tvad Member
    That's the conundrum.
    The Model 3 is primarily my wife's car, so a jack and patch kit is not much use to her. She either needs a reliable tow service or spare tire.
  10. jebinc
    Seattle, WA
    That makes sense.
