siucity
Button Pusher
I rotate the tires myself. However, looking at the tire tread depth of each tire, I probably don't need to rotate the tires at all. All 4 tires are wearing evenly.
Question? Do you need multiple jacks? Is it bad to jack the car up one tire at a time?
Thanks
Thanks
It's not a problem I jack up one wheel at a time all the time when swapping summer/winter wheels. If you want to rotate front to back, I would not trust any jack to jack up the car high enough to get both wheels off the ground. Use two jacks. They're pretty cheap.
Tesla will rotate any OEM tires free of charge, when needed, period. Have verified this with multiple SvCs in multiple regions.
That means you could buy a replacement set from Tire Rack, have them sent directly to the SvC of your choice, and Tesla will mount and balance the set for $125. Or you could have them sent to Costco who will do the same for $100. Or you could buy them from Discount Tire and negotiate the best deal you can get. Regardless, whether the tires are from the factory or a replacement set that you bought from wherever, Tesla will rotate them free of charge *as long as they are exactly one of the OEM tires*.
So for the 19"s, that means either Goodyear Eagle RS A-2s, Michelin Primacy MXM4s, or the new mystery Goodyear Eagle Touring tire. The latter, rumored to cost about the same as the Primacy, has no treadlife warranty and is rumored to have foam inside, which makes it a very quiet tire.
Having typed all of that, I concur with all of the reasons above to rotate them at home, and as soon as I acquire multiple jacks, hockey pucks, and proper jack stands, a 21mm 6-pointed socket, a breaker bar, and repurpose my torque wrench, I intend to do just that.
I can't rotate on the P85+ just buy new tires every 8000 miles.
Thanks
How do you put it on the jack stands since the jack points are only big enough for a jack? Do you jack the rear so high that you can place a stand on the front? If so, how can you then put a stand on the rear since there is no longer a point to jack from?Normally rotate and change my wheels and tires. Have Jackpoint jack stand which work great. Have an adapter for Tesla. When rotating tires should only do it with jack stands otherwise not really safe. For changing from winter to summer or visa versa jack only is probably OK.
The way I've always done it is with one jack, and I only rotate when switching from summer tyres to winter tyres. Just make sure you mark the tyres going out with where they were so you know where to rotate them to next season!How are you going rotate tires jacking up only one corner at a time?
(Guess winter isn't really a thing in California. Maybe make up a random Performance season and switch your performance / non-performance tyres once or twice a year?)
Having two sets is a bit of a necessity up here, though not everyone does. When the snow flies you can very easily tell who put 'em on and who didn't ...Ahh. Well if you have two sets of wheels
