Are you doing this for cost savings or easy rotation? I'd personally much rather put cheap tires but Tesla-spec rather than out-of-spec tires.
- If you want to do this, you may have to get 265 rims for the back, since the rims in the back are generally 275.
- I wouldn't recommend it at all. The Model X is slightly wider in the rear, and generally is a very heavy car where the rear tires take a huge load.
Wow. So what I'm reading in this thread is that even though I have staggered 20-inch wheels on my P90DL X (20x9 front and 20x9.5 rear), that I can still buy four identical tires and rotate them? This is huge news. I might change my new tire order since they didn't arrive yet.
Some thoughts about Continental DWS06 Plus:
255/45R20 on all 4 wheels : XL rated. And Continental page says this size tire fits rims from 8 to 9.5 inches. If not towing, will these tires meet the weight spec?
265/45R20 on all 4 wheels : This seems like a great option, except that this specific Continental tire is not XL rated in this size for some reason.
275/45R20 on all 4 wheels : XL rated. This works, but I've seen reports that during extreme turns, front tires can rub.
Has anyone put four identical tires in 255/45R20 size or 265/45R20 size on the staggered 20-inch wheels on their X?
Personally, I always considered staggered tires a feature. I never have to rotate my tires. Cool!
275/45R20 will not work in the front . Discount tires had wrongly mounted my 275/45R20 tires in the front during tire rotation and I had to bring back the car as it was rubbing during turns.Wow. So what I'm reading in this thread is that even though I have staggered 20-inch wheels on my P90DL X (20x9 front and 20x9.5 rear), that I can still buy four identical tires and rotate them? This is huge news. I might change my new tire order since they didn't arrive yet.
Agree with you , I did not consider changing the wheel. So basically what you are indicating is if you want to go square on MX, you will either have to change the front or the rear wheel so that they are all compatible for square tire mounting 265 or 275 for all four tires .275/45 R20 will work... If you switch out your wheels to thinner ones, you can put 275s all around.. (Or, get a set of front wheels only and put them on the back with 275s on them).
I'm running 275/45R20s all around on my X and no rubbing issue or wear marks.
Thx, i now have a proper understanding of all possible options.Correct - the easiest way is (if you want to stick to the stock Tesla design), pick up a set of front wheels and use them w/275s (or 265s) and go square... Then you can rotate without issue... The problem becomes with the stock set if the rear wheels themselves move up, since they are slightly wider than the front; turning those will lead to rubbing issues.
I went with 275s all around for the higher load rating and slightly more surface area.
Not sure this is true.Agree with you , I did not consider changing the wheel. So basically what you are indicating is if you want to go square on MX, you will either have to change the front or the rear wheel so that they are all compatible for square tire mounting 265 or 275 for all four tires .
you cannot put the 20x9.5" wheels (with 275s) from the rear to the front. it will rub the metal uprights and causing major, major metal-on-metal contact. the wider wheel and maybe the difference in offset will cause this metal-on-metal grinding noise.
if you run at "square" 20x9" wheel on all four corners, you can then rotate.
