I might try lowering the AP and use the Ariels as a stopping point when the wing mirror touches themI think 3 bars is impossible! Elon must have shares or patents in WiFi extenders.
I thought an image would be worth a thousand words so here we go:
Firmware update to 2020.20.12
Theoretically connected with 1 bar, sometimes 2
Been like this for 3 days and the green progress bar doesn’t move
I have left the car locked
Frustrating
Oh yes they areI think 3 bars is impossible! Elon must have shares or patents in WiFi extenders.
Got the version from this
Hi,
I have only had my car for 3 days now...still getting used to it. But this update thing it's annoying me. What other options do i have? should I go to a supercharger and update the car there?
I have also changed the channel in the 2.4GHz setting to channel 6, just in case. It was previously in channel 1.
Thanks
In fact, Tesla could add a simple device to extract the Internet signal from a power line.yeah a pity there's no RJ45 Ethernet socket to hardwire the Model 3 into your own network...
Well, my flat is 3 floors (10 m) above the garage and my EV charger is 50 m from the main panel.I find that RCD's and split fuse boxes significantly attenuate the signal from powerline adaptors, to the point that it becomes unusable.
Given that a charge port will (in UK) have at least one RCD upstream and possibly more between another powerline unit
if in its own fuse box, I think that idea will be as much benefit as a weak wifi signal. imho.
It's an older building, build in the 70's, the breakers are thermal magnetic circuit breakers, not the arc-fault and ground-fault circuit breakers.Is you circuit breaker a fuse or RCD? An RCD can severely attenuate the powerline signal. I have witnessed this across several installations and appears to be the normal rather than the exception. I really hope its not the case as I'm about to get another fuse box installed, but the powerline signal will be passing through 2 RCD's, and I'm expecting marginal signal at best.
@joanfa where did your car come from if you have only had it for a few days as the software is many versions old and certainly needs a service booking via the App. as it will not update as described above and in this link Tesla requiring cars to update to new firmware
