I have a 2018 Model 3 Long Range RWD with Enhanced Autopilot, and I often get the UI_a114 "Driving Visualization Temporarily Degraded" error whenever I leave my car out in the sun for longer than 20 minutes and ambient temperatures exceed 75 degrees F. This error disables the ENTIRE DAS (Driver Assistance System), which means no Autopilot, no emergency braking, no blind spot detection, no visualization on screen, not even cruise control is available.
THE PROBLEM: UI_a114 "Driving Visualization Temporarily Degraded"
In service mode, in the DAS menu, it shows this:
THE CULPRIT: 2 cameras (Narrow and Fisheye) that overheat from direct sunlight. :/
I've been examining this problem for a while now and determined that it's excess heat caused by direct sunlight that causes the two cameras to fail. I conducted an experiment: I made a small sun shield with a suction cup to cover the triple camera and left in the sun for a few hours and sure enough, it worked! Obviously I shouldn't have to do that every time I leave it in the sun. Everything works fine in the morning and in the evening when sun exposure is low. I live in SoCal, so it gets sunny and hot often. Setting cabin overheat protection even at its lowest temperature setting doesn't help.
SOLUTION: Camera Replacement?
Tesla quoted me $200-$600, depending on what needs to be replaced plus $245/hr for labor.
I found some used triple cameras on eBay ranging from $65-$175. I took apart the camera section and I am confident I can change the part in about 30 minutes or less. Part number I found on the camera was (P)1132925-00-A. Do any of you kind folks know if any triple camera from 2017-2020 will work?
OR always park in the shade lol
THE QUESTION: Should I try replacing the camera myself and potentially save hundreds of dollars? OR should I pay Tesla Service $400-$800 for this reasonably simple repair? I can always return the used camera and take it in to service if it doesn't work.
