The nice thing about just setting the charge level lower is that you can always bump it up from the app when you're headed home if you need it charged up higher when you arrive.Keep it plugged in. Don’t overthink. Optionally set the charge level lower.
I read somewhere that like 56% or so was the very best spot to keep it to prevent battery degradation. Any thoughts on this?
If one doesn't drive much, for battery life, is it best to charge it to 80% then wait until it hits like 40 before charging. Will it be better to keep it plugged in and it will stay at 80%? I read somewhere that like 56% or so was the very best spot to keep it to prevent battery degradation. Any thoughts on this?
If you set charge level to 80% and a few hours later your street has a power failure that lasts a day or so will everything continue charging or will you have to reset in some way ?
Well it's obviously not going to charge WHILE the power is out, so we're talking about getting it resarted after the power comes back. It should happen automatically no problem. The other answer is that you get remote access to the car through the cellular network if WiFi is unavailable.Not understanding this. If my power is out my home network is out as well. I thought the car needed wifi access to communicate with the app unless I am missing something.
Thanks. Must have a problem then. Was out of town and had a power failure. Could not contact the car thru cell service. Had to reboot upon arrival.Well it's obviously not going to charge WHILE the power is out, so we're talking about getting it resarted after the power comes back. It should happen automatically no problem. The other answer is that you get remote access to the car through the cellular network if WiFi is unavailable.
You can test by disconnecting it from your WiFi, and trying to contact the car, or by using the app when you're away from home.Thanks. Must have a problem then. Was out of town and had a power failure. Could not contact the car thru cell service. Had to reboot upon arrival.
Will try that thanks.You can test by disconnecting it from your WiFi, and trying to contact the car, or by using the app when you're away from home.
I think I might experiment of leaving it around 50% charge to level and charge it daily.You do not need to worry that much.
The battery will hold up anyway.
If you still would like to minimize the degradation, here is the facts:
To minimize degradation:
- Do not charge to a higher SOC than needed. When possible, charge just in time before the drive (keeps battery at low SOC when the car is not used).
- Charge often. Smaller cycles/ many (small) charging sessions is better.
