To MCU2 or not to MCU2?
Discussion in 'Model S' started by domodan, Feb 1, 2021.
  1. Akikiki
    Akikiki A'-Lo-HA ! y'all
    Kaneohe, HI
    Couple more things you will notice too. Because the IC is a different one, the black looks blacker. And the upper buttons on the S-wheel no longer reboot the IC. The IC now reboots when the MCU is rebooted. Only the scroll wheels activate the reboot.
  2. domodan
    domodan Member
    UT, United States
    My appointment to get this done is on Wednesday. What should I prepared to setup again? Sounds like the EQ and garage door openers will need to be reset. Well I need to rename the car? Reconnect to my WiFi? What about driver profiles?
    Thanks in advance.
  3. Akikiki
    Kaneohe, HI
    From reports we've heard some people retained all settings others - none and a few in between. It appears that some SC techs are better at saving and restoring profiles that others. That's a guess since no one will 'fess up to the differences. So do you have some settings that you need enough to document them before you take it in, as you can put them back yourself.
    You should expect to need to reconnect your WiFi. Your MCU2 has a different WiFi modem (2.4 & 5 GHz now), so your home network would not know it.
    When my SC did my upgrade, they restored everything expect the WiFi connection. I thought that was normal. Mine was the first upgrade my SC had done. But since, I have heard many people say everything was gone. What's important to you?
  4. mthoring
    mthoring Member
    Norway
    For me, the only two things I've noticed that didn't carry over was radio favorites and Homelink. For Homelink the saved entries was present but didn't work. After trying to reprogram I eventually had to reboot the MCU to get Homelink going. Audio sounded horrible with my old settings so tweaked the EQ using the results from another TMC thread (you'll find it if you look). Backup cam is darker, but functional using creep and brakes for additional lumination. 2.4GHz WiFi-reception is better than before.
  5. JLSpencer
    JLSpencer New Member
    Indiana, USA
    Just to add another data point - my upgrade started around 8:40 am and finished around 2:30 pm. I retained all settings except Homelink and Wifi. It took a couple tries (and one reboot) to reconnect to my Eero home network.
  6. wooter
    wooter Nou ik heb niet te klagen over Tesla support
    Belgium
    That's odd. I've upgraded to MCU2 in my Model X and I can reboot the MCU and IC separately.
  7. random155
    random155 Member
    NJ
    Car is in for upgrade right now. I'll update when I get it back. I'm posting now to ask is there anything I should definitely check before driving away with the car? Anyone have any issues after the upgrade that needed fixing?
  8. Akikiki
    Kaneohe, HI
    Yes, its been reported several times. Before you drive away, use your app only. Unlock/lock the car. Start the car using the app. The issue is a few times SCs have forgotten/missed enabling the security certificates to unlock/start the car. And some what related, if they are using contactless return of your car and the certs have not been enabled, you will not be able to unlock the car and drive away. If you are picking up after hours, you will wish you had brought your spare fob.
  9. Crutonius
    Crutonius Member
    Salt Lake City, Utah
    I didn't notice until I was gone but the main screen was a little bit crooked.
    Also check the sound quality.
  10. fcastrillo86
    fcastrillo86 Member
    Vallejo
    Dropped mine off for an 0845 appointment today. Hoping it finishes today (the app says by 5pm today) but the Adviser told me it might take until tomorrow to finish. Also getting it looked at for possible uncorking. Cross fingers!
  11. 20165MS
    20165MS Member
    North Jersey
    Check to make sure they didn't damage the aluminum trim above the MCU. They damaged mine pretty good. Also, they creased my dashpad as well. Have a Ranger coming to replace it tomorrow actually.
  12. random155
    random155 Member
    NJ
    Mine was pretty quick, 8am - 12pm and done. Stereo still sounds good (premium audio). Everything looks much crisper, brighter and smoother scrolling. MCU2 is very fast compared to MCU1. I have 2 issues: 1- It appears there is some type of screen burn in on my IC screen. I can see a ghost image of my car that way it appears on the IC screen when the car is not on. 2 - my Teslaoffer automatic frunk opening no longer works. When I push the frunk button the release does not move to allow the frunk to open. It pops up (unlocks) but the actual release never opens.
  13. fcastrillo86
    fcastrillo86 Member
    Vallejo
    Awesome they could get it done so quick! Weird issue with your IC though, doesn't the infotainment upgrade also include a physical IC1 to IC2 display swap?
  14. Need
    Need Active Member
    SoCal
    Same thing here. Homelink remembers the name of my garage, but it just won't open it. I have to delete and set it up again. Probably because my garage door opener has a Learn button for the rolling code thing. I did not reboot for the WiFi. I just deleted it and added it again.
  15. random155
    random155 Member
    NJ
    IC screen ghosting for a now gone and my auto frunk opener started working again after a software update. I’m very happy with the upgrade. You can see the ghosting in this picture.
    • Informative x 2
  16. 2101Guy
    2101Guy Active Member
    weird. I can confirm that the Teslaoffer version 3 works fine with a model S with MCU2 upgrade. I did the install AFTER the MCU2 upgrade, so wondering if something was knocked loose under the frunk during their install. Try pressing the button on your Tesla offer control box twice in fast succession to reset the latch.
  17. Need
    Need Active Member
    SoCal
    For the frunk, there is a time limit that if you don't open it after certain amount of time of popping it, the latch will re-engage. I think it is a safety feature so you don't accidently popped it and it opens up while you are driving. Maybe you just waited too long the first time?
  18. random155
    random155 Member
    NJ
    It’s working now after a software update. The actual latch wasn’t unlatching. All is good now.
  19. random155
    random155 Member
    NJ
    MCU1 vs MCU2 back up camera night quality.
    • Informative x 3
  20. dark cloud
    dark cloud Active Member
    BC
    Just wondering why the brighter one (MCU1) is 361 kb vs. 242 for the MCU2?
