Noob to the Tesla world (just into my first month with my M3RWD) and want to understand the "predonditionning" question...so here goes.
I understand the "preconditioning" of the battery as I'm driving towards a SC, i.e. prepare/heat the battery for the "charge" it will receive.
At home I'm parked in a 2nd level undergroung spot and plugged in.
So the question is: if I need to go out around 10am, do I need to do anything?
My understanding is, and this is were I would appreciate clarification, I can start the HVAC prior to departing to get the car comfy for the passengers which also "heats up" the battery. But seeing were I'm parked my car is always "comfy". So do i HAVE to turn on the HVAC for the sole purpose of "heatng" the battery? Or do I just drive off.
Lastly, should I adopt the same behaviour all year long?
Hope my question is clear?
Thanks in advance for any responses.
You don't have to precondition before leaving in the A.M. but doing so has some benefits, even if you only precondition for ~10 minutes.
Preconditioning for Supercharging is a special form of preconditioning, only happens while driving when using the Navigation system to navigate to a Supercharger. Standard preconditioning takes place while the Tesla Model Y is parked, whether plugged in or not.
You may be comfy at 10C or 15C but the Tesla battery is not at full operating temperature until ~21C. Regenerative braking will be reduced whenever the battery is not fully warmed. (You can now enable friction braking to compensate for the reduced regenerative braking so the Tesla Model Y will slow accordingly when you release pressure on the accelerator pedal.)
By warming up the passenger cabin before driving the heat pump will not need to work as hard once you set off driving. This will improve your driving efficiency and range, especially for short trips of under ~20 minutes.
You can set the heated steering wheel and heated seats to come on automatically while preconditioning, turn the climate control down to a lower temperature if you wish and still be comfortable.
The Tesla Model Y's climate control system will warm and dehumidify the passenger cabin, this will help keep the inside of the windows from fogging.
Experiment by setting a Departure Time for Monday through Friday of 10:00 A.M. and then decide if you would prefer to precondition manually using the Tesla app or not at all.
Preconditioning is arguably more useful in winter as this will warm the passenger cabin and partially warm the battery. In summer preconditioning for even just a couple of minutes means not getting blasted in the face with warm stale air as you enter the Tesla Model Y.
