Today's Trip Meters Conundrum
Discussion in 'Model S: User Interface' started by brianman, Jul 24, 2013.
  1. brianman
    brianman Burrito Founder
    #1 brianman, Jul 24, 2013
    This image was not doctored (other than the red ellipse) and is not fake.
    Any ideas what's going on here?
  2. Doug_G
    Doug_G Lead Moderator
    Ottawa, Canada
    You reset Trip B, drove 200 feet, and then reset Trip A?
  3. brianman
    Both meters were at 0 when I took delivery. I've never reset either of them.
    Had 65 miles at delivery, for those not wanting to do the math themselves. I've had that number memorized for a long time. :)
  4. cfOH
    cfOH Member
    Cincinnati
    No idea about the trip meters, but I did notice that 451 Wh/mi average. Well done, sir! ;-D
  5. brianman
    Heh.
  6. superraz375
    superraz375 Member
    Dallas
    Perhaps the Tesla Motors factory was testing your car.
    They reset one of the trips (while the AC was still on) and then reset the second trip.
    This would explain the slight difference in energy between the two.
  7. brianman
    #7 brianman, Jul 24, 2013
    Shouldn't I have been seeing this discrepancy for months now? I just noticed it today. I'm not saying it started today but it wasn't originally mismatched.
    Update:
    Skimming back through my pictures, the numbers were matched at 934.8 owner miles (1,000 vehicle miles) and at 10045 owner miles (10,110 vehicle miles).
    The discrepancy began sometime in this range (2013/07/11:07:27 PT, 2013/07/11:19:47 PT).
    Now that I have an interesting timeframe to research, I've fired off a mail to ownership because I'm very curious. Not concerned, just curious.
  8. SCW-Greg
    SCW-Greg Active Member
    Beaverton, OR
    Because you car *is* truly like a spaceship. It's the difference in time the neutrinos took to arrive... versus all other electrons. You might notice that you car looks bluish from the front and reddish from behind... with those numbers your puttin up on the board! ;)
  9. Klaus
    Klaus Member
    Even more impressive - >900 Whr/mi between miles -5 and -4 on the history graph.
    brianman, you'll probably need Leilani to dethrone you from the apex position of energy users @ TMC ☺
  10. brianman
    She somewhat acquiesced at my request for a ride in her racecar, but it wasn't at Teslive. At least, that's what I recall she said in one of the threads... but I might have just wanted her to have said that.
    - - - Updated - - -
    It's easy to burn juice going uphill.
  11. NigelM
    NigelM Recovering Member
    Northern Virginia
    'A' measures the front wheels and 'B' measures the back wheels, when you get a little slippage from a wet surface, or in your case more likely from worn tires, you use more fractionally more power without achieving additional forward motion.
  12. brianman
    Now I'm confused. How is power applied to the front wheels?
  13. NigelM
    Northern Virginia
    You don't have the AWD version?
  14. Doug_G
    Ottawa, Canada
    A is the left side, B the right, and you've been driving in circles lately...
  15. brianman
    So Spark keeps telling me.
    - - - Updated - - -
    Where are those puppy dog eyes again...
    Update: Found 'em!
  16. Discoducky
    Discoducky Active Member
    Seattle
    More data points are needed. I doubt they are diverging but rather have a different algorithm applied. When you drive do they update at the same time?
  17. brianman
    I noticed it on the way home, so I don't have a lot of observational data yet. Looking back through my pictures the biggest gap I see is 0.2 and the smallest gap I've seen since the evening of July 11th is 0.1 kWh. On the way home, I noticed that the 0.2 separate displays only briefly and then it snaps to 0.1 so I'm guessing they are like 0.11 or 0.12 kWh apart.
    Prior to this report, I had no reason to think the two trip meters were any different. They're just "A" and "B" with -- I thought -- the same behavior just a different set of storage locations for the data.
  18. deonb
    deonb Supporting Member
    Redmond, WA
    I would think what happens is that the Total Energy is constantly being archived while you're driving. So e.g. every microsecond or so it's taking the current kW usage and archiving the value as kWh over time. (Assuming it's a digital and not analog measure. However, even with an analog measure there has to still be a process of archiving rotations into digital measurements).
    Anyway, it has to do this in several places, adding the number to Trip Meter A, Trip Meter B, and Since Last Charge.
    However, I bet it's not doing the update while under a lock. With the result is that if the archiving is done, and there is a reading change at the exact few nanoseconds between updating Trip Meter A and Trip Meter B you can have a slightly different value added to each of the 2 numbers.
    It probably also doesn't help that there is rounding involved.
  19. Todd Burch
    Todd Burch Voltage makes me tingle.
    Smithfield, VA
    My guess is that the numbers are being truncated to one decimal place instead of being rounded, plus they're using floats to store the data and enough mathematical operations have been performed (integration using the Trapezoid rule, perhaps) that some error has started to creep into a decimal place?
    If they're truncating, the difference between the two at delivery could have been 0.9999999 kWh, and the difference now 1.000000001 kWh.
