Al Sherman
It's about THIS car.
(that rep did mention some things like 3 new wheel sets being offered by end of summer - factory 19" turbine wheels
That would be great. I'll order them as soon as they're out. Hopefully in time for snow tires.
Lowering the amperage does nothing for me.
Although one night is not much of a data point, I dialed down the charge amps last night to 20 amps from 40. As a result I woke up to 296km range, up from 291. That is fairly significant for only one night and seems consistant with the battery balance you guys have educated me on. I'll dial it down some more and keep it low and hopefully soon I'll be back up to 305km or more. Thanks again guys.
Battery balancing does seem to be something Tesla should be more active in educating owners on, eh?
How many times did you do this? (Weeks on end?)
Don't forget that charging at a lower rate means you finish charging later which means if you go and check the car at the same time in the morning, it's not been sitting around suffering from vampire loss as long. These numbers you're observing may simply be the result of that.
I'm pretty sure I mentioned early on that I only use numbers I get at the exact time charging is complete.
EDIT: Just checked. Mentioned it a few times.
It sounds like most standard charges are about 240 miles. My car is less than a week old and that is what I get as well. I've been out of town for 3 days now and noticing a 5-7mi loss of range each night (it is 75 degrees in my garage right now). I will track it for the next 3 days, but is this a consistent, recurring loss? It won't happen that often, but important to know if you are at the airport or on a trip without a charge that you need to factor this in to the return.
Maybe stop reading the thread?I've lost another 2+ miles since I started this thread.
Still nothing but "it is normal" from Tesla.
