Ton - Miles / kwH Metric
Owner
1,532
322
San Francisco Bay Area
I have been calculating metrics on electric car efficiency on my blog. Ton - Miles / kwH seems like a good metric to judge the engineering efficiency of the car. It isn't as practical as a day to day MPGe or Miles / kwH, which I prefer. But it does provide an insight into the engineering built into the car.
Thoughts?
jdh
12
0
Don't you think the 60KWh version will be lighter than the 85KWh, at least partially accounting for the increase in MPGe?
If you were to assume the same Ton-Miles/KWh for both models, then the 60KWh should weigh 4280lbs (367lbs lighter).
I guess we'll see when Tesla publishes the curb weight for the 60KWh model, or someone takes delivery of one and takes it to the scales.
jdh
12
0
My 367lb number was based on your table assuming equivalent efficiency at Ton-Miles/KWh for both models. I just solved for X where Ton-Miles/KWh = 6.11 and KWh/100 Miles = 35
ItsNotAboutTheMoney
10,228
7,322
Maine
Ton-miles really isn't a good measure when you include the car. What matters are passenger-miles or cargo-miles. Or maybe fun-miles.
Owner
1,532
322
Ah, reverse engineering based upon the Mpge numbers in effect. I'll wait to update the table when the actual numbers are released, and they will probably be very close!
