I was under the impression that my heating (no heat pump) was suddenly much stronger, with fan speed staying around 5 on auto much longer than it used to. Also Wh/Km went significantly up.
A ranger which came today to check on the recent front latch recall and install the HEPA upgrade did confirm that this is a known issue. The update aimed at fixing the heat pump issues has the heat sensors off for older cars and heat is blasting like crazy.
Should be fixed in one of the next software release.
