Took No-contact delivery today 2/6/21 vin104xxx
Braveanthony
18
Los Angeles
I took the delivery today. They dropped it off in front of my house. Received the text saying it’s been dropped off. The paperworks were in the car aong with prepaid fedex envelope.
While feeling ecstatic, I am also disappointed with fit and finish. I am not sure if this is “acceptable”. Can you guys take a look and let me know if this is normal?
jcanoe
1,230
1,254
Maryland
Can't tell much from your photos.
What is the fuzzy material in the passenger rear door photo?
The grey material in the headliner photo could be adhesive or it could be sealant from the glass roof; should be easy for the SC to remove the excess material.
The gaps are not unusual.
Do all of the windows work? Do all of the interior door open buttons work? Do the windows all lower about 1/2" when you open the door? (You should re-calibrate each window actuator.)
What about the hatch and the frunk release? Do the seat heaters all work? What about the steering wheel heater?
Do the second row seats release via the switches in the hatch area?
Does the charge port open and close?
When you put the wipers in Service Mode do they clear the lip of the hood?
Make a list and forward to Tesla ASAP.
Schedule a service appointment to have the SC adjust the driver's door.
Braveanthony
18
Los Angeles
What is the fuzzy material in the passenger rear door photo? I think it’s the new car wrap.
Do all of the windows work? What about the hatch and the frunk release? Do the seat heaters all work? What about the steering wheel heater?
All windows work, both hatch and frunk opens, i will try the heated seats and steering wheel.
Does the charge port open and close?yes
When you put the wipers in Service Mode do they clear the lip of the hood?yes
Make a list and forward to Tesla ASAP. Ok
Schedule a service appointment to have the SC adjust the driver's door. The soonest available appointment date is 2/18, which is 10 days out. Is this normal? Thank you so much for the guidance!
jcanoe
1,230
1,254
Maryland
You could try a different SC.
Also, make sure the HVAC puts out heat.
You have to drive a short distance before the TPMS will wake up. Make sure all four TPMS are working.
jcanoe
1,230
1,254
Maryland
Was the Mobile Connector kit inside the vehicle? The Mobile Connector kit should include the NEMA 5-15 plug adapter and the Tesla J1772 charging adapter.
Are both hatch area carpeted floor covers in the vehicle (the smaller cover closest to the 2nd row seats and the larger one that covers the large storage bin)?
Were the front seat driver and passenger carpeted floor mats in the vehicle; also the second row carpeted mat?
Is the tow bolt in the Frunk storage bin?
Check that the windshield washer is working. (You may need to add washer fluid as Tesla does the not completely fill the reservoir (the reservoir holds over ~1.2 gallon of washer fluid when full.)
Check that the dome lights work (press the lens to manually turn on and off.) Check the floor lighting and the center console lighting. Check that the glove box opens via the Quick Access screen or by voice command. (The USB stick drive should be installed inside the glove box.)
If your phone supports wireless charging (and fits) check that both of the wireless charging pads in the center console are working.
Check the driver and passenger seat adjustments including the lumbar adjustment (the lumbar adjustment should inflate/deflate and also be able to be moved up and down.)
Reactions: jedanielee
Braveanthony
18
Los Angeles
Update. Took it to local Tesla SC. A pillar now looks better although still not perfect. Frunk lid still sticks out. Driver’s side door still needs slammed shut. Hatch and roof misalignment looks much better. Found incomplete paint on door hinges. Not sure if it was there or new one while trying to adjust side door panels.. should i try making another appointment?
hcdavis3
HCD3
Mar 3, 2019
1,814
1,058
02571
I would have rejected it. I’m lucky my car was perfect at delivery.
Reactions: WiseShepherd
Jefrucci
24
22
Virginia Beach
I agree!!! I’m sorry but you pay that much for a car it better be near perfect!!! I’m scheduled to take delivery on my first Tesla next weekend and I can tell you I will not leave the lot with that car if I ha e to slam the door to get it to shut!!! I’m sorry that you are having to deal with that!!! Good luck!!!
Reactions: hcdavis3
Jefrucci
24
22
Virginia Beach
Just out of curiosity did yours have the updated center console?
mk677
127
57
jacksonville fl
normal? no, common? yes! sadly tesla has still not been able to get the QC issues sorted out.
  • Disagree
Reactions: qdeathstar
bharath9
62
21
DALLAS
Is house delivery an extra cost option? I am in North Texas and planning to order a Y within the next day or so.
I'm in north texas as well, ordered MY 7 but they didn't have home delivery as an option, not even for a fee. It gave an option to pick it up from Tesla service (plano).
HughH
14
0
Arlington TX
Thanks for the replies. I just ordered a Model 3 today. The website information indicated that they had no delivery to my home area at this date. However, the SA assured me that the Plano site has in-home delivery team at no extra cost. THAT is what I call GREAT service!
Braveanthony
18
Los Angeles
Thought 8 would give update.
After my original post, I found more issues.
Pics attached.
I took it to two different SCs but I didnt notice any change. I even suspect if they even bothered to make adjustments.
So I took it to another SC. The moment I scheduled for service, I knew this one was different. They messaged me asking for photos from different angle. When I dropped it off, they listened very carefully and I could tell they are serious. The service manager said that the doors are tricky to get them perfect but would give it his best shot. They even gave me a model s loaner. 48 hour later, i got the message saying it’s ready to be picked up. Guess what, they are now perfect. The frunk lid, both drivers and passenger doors, gap above the rocker, I mean I don’t think i will get a better one if I ordered another one.
So the lesson is that every SC is different. There are good ones and bad ones. If you have quality issues and you took delivery, bring it to different SCs and you will find one that can make it right!
