torch slider 4wd
Discussion in 'Model S: Driving Dynamics' started by NielsChr, Jan 14, 2015.
  1. NielsChr
    NielsChr Member
    Denmark
    First of all, I have yet to drive a 4wd Tesla.
    But during driving my P85 I did enjoy how a backwheel drived car handled - comming around a corner and strighten the car with the "gass" pedal was pure fun.
    I asume this is not the same in a 4 whel drive car where the fun is in the curve, not when you streighten up.
    I hope Tesla will at some point make it user selectable where the torch should be.
    e.g. "auto" and/or a slider (like the sunroof) where user can select where the torch should be - e.g. 70% rear and 30% front.
    This way you may set it to pure frontwheel drive for economic drive, rearwheel drive for fun, or any point in between. - there should of couse be a indication where optimal setting are at current speed and a way to select "auto".
    this way I will not miss my P85 driving style :)
    does this make sence ?
  2. rdrcrmatt
    rdrcrmatt Member
    Milwaukee
    You want a software adjustment for the torque bias between the front and rear drivetrain, yes your post makes sense!
    I think it is a great idea!
    There's no traction control off mode in the P85D that I've seen yet, no more snow donuts? That's one of my favorite things to do in my P85.. silent donuts.
  3. EarlyAdopter
    EarlyAdopter Active Member
    Redmond, WA
    The P85D is definitely rear wheel biased, and a flick of the throttle on early exit of a corner will kick in some oversteer. While you can't disable traction control on the P85D, it's definitely sports tuned and will let you get into quite a bit more trouble/fun than the P85 will before the stability control nanny kicks in and cuts the throttle and fires the brakes.
  4. LetsGoFast
    LetsGoFast Active Member
    Virginia
    Can you still disable it by pulling the fuse? I was thinking I might enjoy doing that one of these fine days.
    I'm going to use "torch" for "torque" for a while. It is unclear to me how Tesla allocates power between the axles. It seems to me that it drives like an AWD car in hard cornering.
  5. Denarius
    Denarius Active Member
    Utah
    I was able to do donuts after enabling "slip start".
  6. rdrcrmatt
    rdrcrmatt Member
    Milwaukee
    where / what is that? (I haven't driven one yet)
  7. Denarius
    Utah
    I should clarify that that I did donuts in the snow. Couldn't do them without enabling slip start.
