Torklift Central's 'The Law' removable front license plate bracket
Discussion in 'Tesla Parts for Sale' started by Torklift Central, Oct 29, 2013.
  1. Torklift Central
    Torklift Central Former Vendor
    Kent, Washington
    Torklift Central manufactured an aftermarket solution for a removable bolt on front license plate called The Law.
    Torklift Central - The Law
    Easy install and easy removal. Great solution for someone who does not want to modify their vehicle.
  2. tomas
    tomas Out of warranty...
    Chicago/Montecito
    Great, thanks! Best solution yet. If I hadn't already done the Skene, I'd buy one.
  3. Gizmotoy
    Gizmotoy Active Member
    Bay Area, CA
    Looks interesting. Any chance we could get more pictures, especially from the side, or the installation instructions? Does it sit behind the nosecone/front spoiler, or put another way, does it stick out from the bumper?
    Based on this: "If you do not hand wash your Tesla, remove the bracket prior to entering any automatic rotating brush style car washes." I assume the plastic mesh of the grille is not terribly sturdy. I wonder if the clamping force of those bolts will damage the grille over time...
  4. Torklift Central
    Kent, Washington
    #4 Torklift Central, Oct 29, 2013
    For installation instructions, you can contact our shop and they will send them. The bracket sits on the bottom grill piece and can be placed anywhere you prefer on that piece.
    Install video:
    I have attached a few more images of the Torklift Central Law. You can see the bracket is designed to not touch the front bumper at all.
    We did all of our testing on an actual Tesla grill to ensure durability.
    The bracket is inserted into the grill by sliding one of the pieces in the openings. (see below)
  5. skdave
    skdave Member
    Lake St.Louis, Mo
    I did the same thing with 4 toggle bolts and 4 spacers total cost $3.00 Note you need to choose the "Small" toggle with 4" bolt which you can buy at any good hardware store.
    - - - Updated - - -
    I would not put my TESLA in a brush car wash.
  6. Gizmotoy
    Bay Area, CA
    #6 Gizmotoy, Oct 30, 2013
    Nor I, but the fact the disclaimer is there certainly gives pause. I thought I was being clear, but perhaps not. Air is constantly going to be pushing on the plate (with huge force, at highway speeds). That grille is just a thin plastic honeycomb. I was wondering how this force is going to affect the grille over time, especially with only two mounting points such that it's providing a twisting force, which plastic is not terribly resistant to. The disclaimer would seem to indicate the bracket is not terribly sturdy, hence my concern.
    Looks like a well-constructed part. I don't see anything else you could do to make it safer, other than reduce the distance from the plate to the bumper. I suspect it's that far because it bends substantially at speed, though.
    What would be interesting is to find out how much that grille costs. It looks like Torklift purchased one, maybe they can chime in. If it's relatively inexpensive, even if five years down the road it has damaged the grille a bit, it would probably be worthwhile for the superior mounting location. Just replace the grille. If it's cheaper than the nosecone, even better.
  7. Torklift Central
    Kent, Washington
    #7 Torklift Central, Oct 30, 2013
    Torklift Central The Law - Removable Front License Plate
    For research and development of the license plate bracket, Torklift Central purchased the actual Tesla grill to test the strength and durability. The grill was around $75 from Tesla factory.
    The bracket is designed in such a way as to distribute the force evenly across the mounting surface. Regular wind force is not enough to bend or distort the bracket. The reference to the car wash is that the physical machines that come in contact with the car have the potential to wrap around the license plate and pull on the license plate bracket with far more force than it would ever see while driving.
    The bracket is $104.95 with free shipping
    A link to the product can be found here
  8. Gizmotoy
    Bay Area, CA
    Thanks for the clarifications. All great news, especially with the grille being so inexpensive. I hadn't expected the bracket to bend (it looks like very sturdy metal), but thought the plastic grille or thin license plate might. If there's no flex, any reason why the plate doesn't sit closer to the bumper? Maybe it's hard to tell from the pictures, but it looks like there's a lot of space there to do so.
    In any case, thanks for producing the bracket. Looks like a very nice product.
  9. Torklift Central
    Kent, Washington
    There is approximately 1/2" between the license plate and the nose cone on the Tesla. This is to ensure that the license plate does not touch the nose cone and potentially scratch the vehicles paint.
  10. h1diaz
    h1diaz New Member
    PA
    Can you show us how you did it with the toggle bolts?
  11. MATTEmarc
    MATTEmarc Member
    New York
    will the ezpass license plate tags work on the product
  12. pdx4s
    pdx4s Member
    Portland, OR
    TC, may I suggest to shorten the plate or allow it to be adjustable so it can be flashed with the front surfaces and wrap the license plate with rubber/plastic to protect the car surfaces? as mentioned the concern is how much the grill can sustain like small frontal bumps into the plate.
    Thank you so much for bringing this product to us.
  13. pl804
    pl804 Member
    Any updates on how well this has worked for TMC members over time?
  14. dsm363
    dsm363 Roadster + Sig Model S
    Nevada
    Have had it on since the end of last year. No issues so far.
  15. AEdennis
    AEdennis Active Member
    Had it for about a month and taken it as fast as 90mph... Works just fine, however, it took a bit longer than 5 minutes to install (closer to 25 minutes).
  16. dsm363
    Nevada
    Yeah. I have no idea how they put that on in 5 min but no issues with it.
  17. SanCarlos
    SanCarlos Member
    Bay Area
    I've had it for three months and have also had no problems. It did take 25-30 minutes to install but it wasn't difficult.
