Duckjybe
Hope so!
And that will make that pesky draft coming in the triangular windows easier to take as well!
I am getting it as well.
Hope so!
For what it's worth, I had my triangle window adjusted and still get cold air in that area. A little experimentation has convinced me that it is not coming in from the window seal, but that somehow air is getting into the door panel. I have found that if I set the HVAC to outside air (i.e. turn recirculate off) and bump the fan speed up a bit, the cold air infiltration stops. I think the added interior air pressure is doing the trick. I'm not sure where the air is getting in, but I have a strong suspicion it is through the door handle to body panel gaps.
Took me 7.5 hours from Chicago, including charging. I'm stopping over quickly in Windsor to top up before heading for Milton for the night.
I ended up doing a last minute trip to Detroit from Toronto. I left on Thursday night and I'm on my way back after a short visit to the Detroit Auto Show today. I was planning on charging in the garage near the show but there were a couple of Volts using the spaces so I charged in Chatham for a little bit. I'm stopped for a coffee and a few extra km (as a buffer) at the Coffee Culture near Woodstock Hydro. I'm averaging between 220 and 230 w/km at between 100 and 105 km/h. Not bad considering it's been around -9c.
Overall, it's been a pleasant drive but I'd love the London SC ASAP!
Nice going.
What's the voltage and max current at Windsor?
I am am taking my 100 ft Nema 14-50 extension cord I made so I can wire it in to my friends hot tub connection or use his dryer outlet. This is why we need Superchargers in Cities!
I read those posts the other day, I might try range charging @ 120V this weekend...
FYI, dryers use NEMA 14-30 outlets which are different than the NEMA-14-50 stove outlets.
Superchargers in cities will never work as long as they're free; there'd always be a queue a mile long. I do agree that we need some sort of DC fast-charge solution though.
I did 3 range charges this weekend (one of them at 5A). It came up to 406km each time. So there appears to be no short term effect on doing a range charge for balancing the battery, or at least the balancing made less than 1km of difference in charge level of the 3 charges.
- - - Updated - - -
This will be interesting to track, for sure. I'll be a good test case for Tesla, I believe. I have to Range Charge most days, and I get very close to emptying the battery each time. My range charges have gone up from 432 at the start, to 434, and Now I'm at 435. And at 435, I drive about 1.5 km before it drops down to 434 (when car is battery is warm and the cabin pre-heated).
I'll keep reporting back. Should we start a new thread? I purchased knowing that I needed to do full ranges a lot more than most, and my car meets my needs each and every day!
435! Wow thats great. Even in this cold?
I wonder what battery version letter you have?
Is there a way to check?
Yeah - 435 Rated is great. And keeps going up. I range most days and empty it out again.
