Total Shutdown of Electronics on Freeway!!
Discussion in 'Model X' started by LoveMX, Feb 1, 2021.
  1. LoveMX
    LoveMX Member
    SoCal
    Has anyone had a total electronics shutdown while driving? What could be the reason? Mine is a mid-2018 MX 75D. It still let me drive, but i didn't have back-up camera as the touchscreen went black!
    Could this be a MCU issue? I upgraded to HW3 last year. I heard about the MCU recall or something to do with the touchscreen but I never received any recall notice. I am about to go out of warranty so am trying to figure out the best course of action.
  2. jboy210
    jboy210 Supporting Member
    Northern California
    MCU1 units were source of recall. Mcu2 was installed on Xs manufactured after mid March 2018 and is not subject to recall.
    I would take it in. Alternatively you could see if the MCU come back after reboot. Hold both buttons on steering wheel down for 5 to 10 secs and release.
  3. Les236
    Les236 Member
    Kissimmee, FL, Boston, MA
    I had this happen to me once while on the highway with autopilot engaged, and had just switched out of the Web interface back to just the map guidance. Everything froze, except autopilot was still driving the car. My speed indicator wasn't changing even though I slowed down (took it out of autopilot), and the map and GPS froze. Then everything went blank. Just a slight panic and can't tell you if I waited and eventually restarted with the two steering wheel buttons or if it restarted on its own. This was with MCU1 which has been changed out to MCU2. As Jboy210 suggested, take it in. Make sure you note the date and time and they should be able to look at the logs. You should be a MCU2 if it was made after March 2018.
  4. scottf200
    scottf200 Active Member
    Chicagoland ModelX S603
    See: Consolidated eMMC Thread (MCU repair) (Black Center Screen)
  5. BeardedBro
    BeardedBro Member
    Sunshine State
    My X has occasionally been doing this- I have an upgraded MCU2 (from MCU1). The first time I took it into service they said they will work on it. It’s been a few weeks, and it’s happened again, I just opened up another service appointment.
  6. MrTuna
    MrTuna Member
    South Bend, Indiana
    Surprising it still drives huh? It feels very weird rebooting your car as you drive it. I’m
    Not 100% clear what can work vs not (cruiser control works. Does autosteer? Does AP? ).
  7. Bigriver
    Bigriver Member
    Pittsburgh, PA
    This was a regular occurrence for me with MCU1 in my 2017 MX.... easily 50 to 100 times. I have had it occur just once in my (MCU2) model 3. I don’t think a single occurrence is particularly alarming regarding the health of your car, although of course it is a weird driving situation. I guess because you are nearing the end of your warranty that you could ask the SC to investigate. I would be surprised if they say anything is wrong.
  8. LoveMX
    LoveMX Member
    SoCal
    It came back when I rebooted after parking. I logged it when it happened so they should be able to look it up when I take it in. I am going to ask them if they will repair/replace MCU at no cost if it happens after my warranty is over since I am reporting it while still under warranty.
  9. jboy210
    Northern California
    I had to rebooted mine while driving once. Everything just kept going. But it was definitely strange to see the displays come up one by one at 70 mph.
  10. animorph
    animorph Active Member
    Scottsdale, AZ
    It's only the MCU crashing/rebooting, which has very little effect on how the car drives. It's not a "total shutdown of electronics". AP uses a different computer and will work normally without the MCU. You do lose your displays, so it's like driving with a non-working speedometer.
    It's been reported here often enough, though I've only had one or two instances in our 2017 MX. It was reassuring to know that when it happened to me.
    • Like x 5
  11. DelPhonic1
    DelPhonic1 Member
    Burbank
    Total shutdown is an extreme statement. Especially if autopilot is still engaged with no interruption and you're able to continue to drive the car. I think the redundancy they have is very impressive, especially since we can reboot mid-drive.
  12. NewFavThing
    NewFavThing Supporting Member
    Evanston IL
    2018 100D with HW3 MCU2 here. This started happening to me after my HW3 upgrade. It’s definitely freaky the first few times this happens, but AP will not crash if it’s been previously enabled.
    To resolve, reboot the MCU while driving by holding the two steering wheel scroll wheels until that nice Tesla T appears.I could always tell when the MCU was about to crash as our streaming Tesla music would begin to skip (like a scratched record). Unless I then pulled off the Interstate to reboot, the MCU would inevitably crash while in autopilot.
    All that being said, my MCU hasn’t crashed on me since October. I’m assuming a software update resolved the issue. I’m guessing the fundamental problem is related to the forthcoming recall to replace that MCU chip with the bad buffer.
  13. RedXowner
    RedXowner Member
    Springfield, Virginia
    I'm no expert, but I would assume many of these "crashes" are the result of not having enough memory. I just received a Tesla recall that said I have only 8Gb eMMC (Oct 2016 MX) and they will replace my eMMC with a 64Gb chip, even though I haven't experienced the blank screen issue but once ever. They are waiting on the supply chain to build up enough of the parts to replace them all eventually at Tesla's expense.
