Neroden, my only other thought for you is to maybe get together with someone who does get an early Model S delivery in your area and see if they are willing to take it (with you) to a couple of different after market shops so that those shops can physically see the car and give you a more accurate answer to what your potential options might be.
Thanks. I guess I am better off as a "later adopter" than an "early adopter".I'm with a lot of others on this thread that it should be possible to work something out. And that said, the smartest move on your part was to cancel your reservation and wait for someone with a car in hand to take it to a customization shop to see what can be done.
Depends on what sticks to Alcantara and how thick the seal would have to be to stop "shedding". Some things just don't stick properly to other things, and it's a substance I don't know much about. Polyurethane sticks to a lot of things, though.At the very least you should be able to have someone just paint the alcantara with a clearcoat polyurethane seal.
Of course if I get a Standard -- now that my Signature reservation is cancelled -- I'll have microfiber polyester headliner, and dash and door inserts, to replace/seal. Actually, customizers may understand better how to seal those more common materials. A customizer could probably *examine* the attachments on a Signature, as the attachment will be the same.That would be crude, but it would work. A customizer will be able to do a much more aesthetically professional job with a greater selection of choices.
I think you could probably use a vacuum bagging process to seal the headliner. You would use the headliner as its own mold to laminate another layer to it sealing away the polyester. I would probably choose an epoxy resin. Someone here may know more than me, but my understanding is epoxy resin creates a chemical bond whereas polyester resins create mechanical bonds (besides, you'd be allergic to that resin anyway). You could even use the process to put new fabric over the existing one if you didn't just want a hard smooth surface. I'd probably do it in a two-step process if I wanted to ensure a perfect covering over the existing headliner.
The process shouldn't be too expensive or difficult. There are plenty of people who build their own skateboards, kayaks, and hobby airplane parts using this process. You could do it yourself if you weren't so allergic -- my main concern would be getting the seal you need without making the headliner too thick to fit back into the car if any other panels need to overlap it.
Indeed. Maybe they'll be willing to do that for some price at some point.The best solution would be for Tesla to use a different fabric during the headliner lamination process for neroden.
I'm confused on why headliner material would make a difference in crash testing. It's not part of the structural integrity of the vehicle. Is it?? The pano roof has no material.
The side airbags have to break through the liner. It's prescored from behind but there's no reason someone can't replace the liner with something non allergic. Probably around $2000 max picking up from a auto upholstery specialist.
"The headliner is approximately 3.0 thick sheet molded compound with fabric laminate covering that is bonded to the substrate in the tool. It can be re-covered (over the top), but the existing Alcantara cannot be removed without damaging the panel. It would difficult to completely pull off the fabric and replace it. I also inquired about a "blank" headliner delivered with no Alcantara. This will not be possible because the material acts as a mold release in the forming process. "
Common sense is not so common. -VoltaireI've had some success with other gov't agencies in using common sense - but it is what it is.
Time for Tesla to make a cabrio of the Model S! No headliner problem then! ;-)
Not necessarily. They may lift the headliner out as a single piece and replace the whole thing, plastic and all, with a new polyester-covered headliner. Expensive way to "repair" it, but not unheard of.I have been watching this thread for some time now and I just don't get it.
Suppose I take my Model S to IKEA and I load it up to the roof with Billy bookcases. With the last one I scrape/tear the headliner. Now please convince me that Tesla cannot replace the headliner in that case. If they can replace the headliner, they can cover it with other materials.
I can imagine however they have other problems than trying to please the need of every single reservation holder. They have a car to build and deliver before July ends and than some more. I suspect they will try and individualize cars when they have production up and running and charge heavily (as is habit in this sector) for special demands.
