After finally taking delivery of my 2021 MY I was researching how to mount my tow hitch bike rack without having to do an extension. As most of you know you can’t use a straight pin with a lock because the electrical outlet is in the way so I got a right angle lock that I was able to use with the existing pin so I don’t have wobble. I own the KAC Overdrive Sports K2 2” bike rack and it’s made to hold up to 120lbs which I need for my 63lb ebike without a battery. A fellow member here recommended this pin lock and it works flawlessly.
