So i have seen multiple opinions on the vertical weight the tow hitch can carry. In the official towing specs it says 500lbs is maximum tongue weight or downward force. Then in other parts of manual it states that 120lbs is max for "accessory hitch". I'm wondering if that is referring to the smaller accessory hitch they used to ship instead of full blown tow package?
Reason i ask is that i was going to buy the x-rack carrier ~20lbs and use it to transport an 15 hp outboard engine which weights about 125 lbs. This was no problem for my old Tahoe but now i'm concerned that I overlooked some key specs before buying the X. Surely if the tow hitch can handle 5000 lb boat/trailer and 500lbs of tongue weight, a 150 lbs off the back would be ok?
Find it odd the limit would be so low as that would hardly support a couple bikes or skiis.
