Towing a Seadoo
apples23
63
18
Toronto, Canada
Thinking about buying a couple of sea doos this summer. A little concerned about towing them w my p3d. They should weigh about 1500 pounds
does anyone have any experience towing w their m3 or even better towing a boat or jet ski?
Need to get them from Toronto to collingwood and want to make sure I’ll have enough range to get between super chargers
anything else I should be concerned about?
Biscuitman
300
135
Ottawa
Please stay away from my lake or I will have to pull out my land to water missile launcher again.
Reactions: Vawlkus
Nairb
140
334
BC
Anything else you should be concerned about?
Presumably you got yourself an electric car, at least in part, to lower your emissions and received government incentives to do so. Sea Doo's and personal watercraft emit something like 10 times the greenhouse and smog producing gases than that of a modern gas car which are subject to much more stringent emissions controls. Plus they tend to leak unburnt fuel into waterways. So using a couple sea doo's for a Summers worth of recreation could negate any efforts to lower your emissions, not just from the direct emissions of burning gas for pleasure, but also from the manufacture of recreational toys like these.
Maybe get yourself a Pakboat instead. Packs down to 35x18x14 inches and should fit fine in the back of your Y. Or put a regular canoe on the roof, which should lower range about as much as pulling jet skis. Better yet, just rent a canoe once you're in Collingwood.
PakCanoes -
Reactions: Biscuitman
DMC-Orangeville
85D and John Deere 5100E
Feb 14, 2015
941
1,164
Orangeville ON Canada
PakCanoes -
Or
Try out this: Orca Electric PWC - Taiga
They gave the Tesla Owners Club of Ontario a test drive last July. Awesome machine, no emissions, and much quieter than a Seadoo
Nairb
140
334
BC
Or
I'd thought of them too after I posted. A good way to support a Canadian startup with some compelling looking machines. They're supposed to be bringing their snowmobiles out west in Feb to demonstrate after doing so in the east the last little while. I'd guess availability to be low for this summer perhaps. They're only just starting to produce the snowmobiles it appears.
Level 2 charging options (3hrs to full) near water are pretty limited according to plugshare, but level 1 could charge it overnight with an extension cord to a dock or trailer. This is going by their FAQ pages with charge info. One could conceivably charge it overnight from the car via an inverter from the 12v socket I suppose. I wonder if they put a high powered USBC on the Taiga, if it could charge overnight from the cars high powered USBC ports?
X.l.r.8
1,507
936
Toronto/Miami
I towed my race car home from Quebec with a car dolly and I ended up looking at half my efficiency, car was stripped and no engine and transmission so 1500 lbs would be generous. I would count on 1/2 the efficiency you are seeing at present and that's including a reduced speed, towing with the model S was far worse than towing with the roadster.
Reactions: Goodtohave
apples23
63
18
Toronto, Canada
Thank you. That’s really helpful.
Goodtohave
396
221
Canada
Agreed
I have a chademo adapter I rent from time to time and someone rented it for a trip with a 100d model x towing a snowmobile enclosed trailer in summer and he said it was a nightmare, about 50% less range. Without the chademo he would have never made it, even with it his trip took forever stopping to charge
