If you go to
Towing with a Tesla and scroll down you will see this text (and some photos):
I opted to purchase the
Weigh Safe hitch ball because it has a built in scale that shows the tongue weight. The scale is not as easy to read as it could be; if the gauge needle was just a few millimeters longer it would touch the scale markers. This photo shows an indicated weight of almost 300 lbs when hitched up to my Alto trailer that was loaded up for a trip. I estimated the trailer weighed about 2,300 lbs.
The Weigh Safe is certainly more costly than a standard hitch ball, but having the correct tongue weight is a
critical safety parameter when towing; it should be between 10% to 15% of the total (loaded) trailer weight. If the tongue weight is too low the trailer can sway uncontrollably; too high a weight and the tow vehicle’s handling can be compromised.
Typically people use a portable scale to measure their tongue weight. But the weight can change depending how the trailer is loaded and how full the various water tanks are (the Alto freshwater tank is behind the axel while the grey and black water tanks are ahead of the axel). Carrying a separate scale is inconvenient and you may be tempted to skip checking the tongue weight before a trip. Having a scale built into the hitch ball means you can measure your tongue weight at any time; very convenient!
The Bosal hitch that is part of the Model X towing package option specifies that the base of the hitch ball cannot be more than 0.75” above the top inner surface of the hitch receiver. When using the Weigh Safe hitch ball that means mounting it as shown above, in what most people would consider the “upside down” position. In that position the ball is within the required hitch specifications, but the part sticking down can scrape when going in or out of sloped driveways, for example. I purchased the 4” version of the Weigh Safe before I took delivery of the trailer. I was unsure of whether it would be best positioned “up” or “down”. It turned out that “down” was required. For the Alto trailer, that is the version I would recommend.
Positioning the Weigh Safe in that manner means it can scrape when going in and out of driveways, for example, so I had it cut down.
