When towing does the estimated range remaining reflect the effect of the extra towed weight and cross section of the trailer being towed?. Eg. Is it dynamic?
Thanks.
Thanks.
Thank you all for the info. It sounds like a good close to home tow vehicle for a smaller trailer but not a long haul solution . Local lakes etc.
Partially. I’ve taken my trailers for decent road trips. It just takes some getting used to and careful planning. I’ve done 12-14 hour trips with mine and managed to average about 500wh/mi. It’s not a piece of cake but it’s not that terrible.
500wh/mi while towing sounds really good. I can use 400+ wh/mi at 75 on the interstate with no trailer. What sort of speed do you do?
Vehicle: Model X 75D, 237 rated range - 4% degradation w/ 22" OEM wheels and Pirelli's
Trailer: 6.5'w x 10'l x 8'h, V-Nose Cargo Trailer, Single Axle, Empty Weight: 1200lbs
Leg 1: Normal settings and driving, 66 miles, 60 mph average, 653 wh/mi, Air Temp: 82F, Peak Climb 566ft, Highway speeds of 70-80mph
Starting Range & Elevation: 90% @ 110ft
Remaining Range & Elevation: 22% @ 930ft
Leg 2: Range mode and normal driving, 40 miles, 58mph average, 638 wh/mi, Air Temp: 90F, Peak Climb 350ft, Highway speeds of 70-85mph
Starting Range & Elevation: 70% @ 930ft
Remaining Range & Elevation: 41% @ 1060ft
Leg 3: Range mode off, Chill Mode Enabled, 117 miles, 52mph average, 509 wh/mi, trailer loaded - ~2750lbs total, Air Temp: 74F, Peak Climb: 315ft, Highway speeds of 55-65mph
Starting Range & Elevation: 89% @ 865ft
Remaining Range & Elevation: 2% @ 865ft
Leg 4: Range mode off, Chill Mode Enabled, 98 miles, 54mph average, 585 wh/mi, trailer loaded - ~2750lbs total, Air Temp: 65F, Peak Climb: 610ft, Highway speeds of 60-70mph
Starting Range & Elevation: 85% @ 865ft
Remaining Range & Elevation: 12% @ 930ft
As others have noted, the energy graph display does a reasonable job of estimating remaining range but only after you have been driving for awhile.When towing does the estimated range remaining reflect the effect of the extra towed weight and cross section of the trailer being towed?. Eg. Is it dynamic?
I disagree. The X can be a great long range tow vehicle if there are Superchargers available along your route. I have towed my 17 ft trailer from San Francisco to Santa Fe, New Mexico, and back and had no problems.Thank you all for the info. It sounds like a good close to home tow vehicle for a smaller trailer but not a long haul solution . Local lakes etc.
On I40 through Arizona and New Mexico I stopped at every Supercharger. I like stopping every two hours or so to stretch and move about a bit. I don’t like sitting for long periods. You can read more about my trailer towing experiences atNice. How often time wise would you say you stopped. Every couple hours etc. Love to see a picture as well.
Towing an Alto F1743 trailer with a Model X and Towing with a Tesla
