i know the towing capacity on the Model X is 5000 lbs but what if you towed more?
What if i towed around 7000? I wanna trailer my race car around to tracks and events. Was wondering if I could or should I get a hitch installed on the Range Rover
If you did that you would risk losing whatever you were towing due to the hitch separating from your Tesla and potentially killing people on the road near you.i know the towing capacity on the Model X is 5000 lbs but what if you towed more? What if i towed around 7000?
the tesla is the wrong tool for the job you want it to do.i know the towing capacity on the Model X is 5000 lbs but what if you towed more?
Legal aspects aside, realize that your range will be cut in half, AND you will need to drive at 55 mph to do even that well on range. Actually your car on an open trailer will likely be a little more aerodynamic than a covered trailer, so you might do a little better...actually, good news on the weight that the car actually weighs 4094 lbs. I just need a trailer that is going to weight 900 lbs. I think I should be good.
Good luck finding a car trailer that light. Even a good aluminum one will weigh close to 1500 pounds. Also, don't you have tools, parts, fuel, or other miscellaneous items as well? I think you are fooling yourself in even considering using the X for this application. You will most likely exceed the tongue rating of the hitch as well.actually, good news on the weight that the car actually weighs 4094 lbs. I just need a trailer that is going to weight 900 lbs. I think I should be good.
Even though it's rated to 5000lbs, I would be hesitant to tow right up to the limit.actually, good news on the weight that the car actually weighs 4094 lbs. I just need a trailer that is going to weight 900 lbs. I think I should be good.
Please note, that @ohmman's setup included a weight-distribution (WD) system, which is against Tesla recommendations. It's likely that the WD system was significantly responsible for the adapter issue. I have only heard of this issue occurring twice now, both times using a WD product.Take a look at this thread by @ohmman and factor in how valuable your race car is . And this is for a trailer under the 5000-lb. limit: Bosal Hitch Adapter Loosening. He has now switched to a more robust option.
If you tow the max tow capacity of a tow vehicle make sure your trailer brakes are set up REALLY GOOD. And don’t skimp on the brake controller. Speaking of which, does the model X come with a brake controller.
How about a weight distribution hitch. Can a weight distribution hitch be used with the frame of the model X????
