I read through your links but couldn't find this. Why didn't you go with the retractable roof version?
The first link I posted,
A “Safari Condo” is not an apartment in the Serengeti… , on that page right after the section “Is the teardrop trailer shape an advantage” (answer; no) is a section titled ”Why I chose the fixed roof Alto”.
Here is what I wrote:
Is a “teardrop” trailer shape an advantage?
Safari Condo claims “…the aerodynamic shape of the Alto, developed in a virtual wind tunnel, creates 75% less aerodynamic drag than a traditional travel trailer. This factor, along with its lightweight, makes the Alto readily towable by most compact cars and small SUVs.” And at about 1,800 lbs, the 17 ft Alto is definitely a lightweight compared to other trailers in its size range: the Airstream Sport 16 weighs nearly 2,900 lbs. Many Alto owners tow with 6-cylinder Subarus and other small vehicles.
My conclusion was that while the retractable roof Alto certainly has less drag than a “traditional” box-shaped trailer, and the low weight does make it towable by smaller vehicles with more modest engines than a Ford F-250 for example, the sharply sloping rear roofline is probably not an advantage. An engineer with aerodynamic experience informed me that air flowing across the trailer roof peak would tend to separate from the roof as it sloped sharply downwards and then would interact with the air coming off the sidewalls, creating turbulence and acting like “twin parachutes” that would increase the energy consumption of the tow vehicle compared to a more gradually sloping roof. A Canadian RV dealership with extensive experience towing a variety of trailers, including every version of the Alto, said that the R series trailers offered no noticeable energy savings compared to the 95” tall F1743 fixed roof version. It was also clear to me that the Model X was a suitable tow vehicle, since Canadian Model X owners Rolf and Silke Sommerfeld were
towing their Alto across Canada and back!
So I turned my attention to the
F1743 model, which still features a generous amount of window area all around while offering more storage and most significantly, an enclosed bathroom. As I compared it to other trailers on the market in the 15 to 19 ft size range, I realized that the 17 ft Alto F1743 had numerous advantages. In a very compact size it provides a queen size sleeping area aft that can be left made up all the time if desired because there is also a very usable two-person dinette table forward which converts to a single bed as needed (with just the two of us, we’ve never had the need for that). The kitchen counter space includes a sink and two-burner stove, lots of storage below and more storage above along with an optional microwave. The 12V 4.3 cu ft refrigerator is positioned below a generously-sized clothes closet. The compact bathroom has a toilet, shower and a small cabinet. Additional storage is available below the sleeping area and dinette seats. Exterior hatches provide easy access to the same storage areas.
Just as importantly, it is clearly made with care and to a high standard, with a very contemporary style. Lightweight materials are used throughout; the trailer frame, exterior walls, and interior walls are all aluminum, as is the floor. There is no wood anywhere; composites are used extensively and the only steel employed is in the axle, suspension components, and tongue. LED lighting is used throughout. The double-wall acrylic windows, made in the Netherlands, include built in adjustable screens and shades. The fresh, grey, and black water waste tanks are located beneath the floor for a low center of gravity. A small exterior hatch next to the freshwater hose connection conceals a shower head and hot/cold water controls for outdoor showering.
The Alto F1743 base dry weight of 1742 lbs is astonishingly light (and slightly lighter than the retractable roof Alto) yet Alto owners with years of towing experience report that the trailer design holds up very well over tens of thousands of miles of travel. In comparison, the 16 ft
Airstream Base Camp weighs almost 2,600 lbs, lacks a permanent dinette area, and costs 15% more. The more traditional looking 16 ft
Airstream Sport weighs nearly 2,900 lbs and offers a twin size bed (48” wide) instead of the queen size (60” wide) that is standard in the Alto, yet costs about 60% more.
The new 16.6 ft
Airstream Nest caught my eye with its modern style, rounded corners, queen-sized sleeping area, and sink in the bathroom (only available in the Alto by special order). But it lacks a permanent dinette table, costs 60% more than the Alto F1743, and despite featuring a fiberglass body shell weighs a shocking 3,400 lbs! How is that possible; are the countertops made of concrete?
