As I read this... I thought this and then read what you wrote and realized that, once again, you were way ahead of me. It certainly is a concern. I hope that Tesla appreciates your input and takes it seriously.
Just throwing a link to a new thread here as it appears Tesla has updated their manual to give (slightly) more guidance on the weight carrying/weight distribution hitch issue. Model X Manual Update Regarding Towing
I have a friend at COTA and he ran into the Tesla mobile showroom. I had him take some close up photos of their hitch setup. Some confirmations: They're using the stock Bosal adapter They're not using weight distribution It appears they're within the 3/4" offset restrictions of the stock Bosal hitch
Hmm...interesting. I wonder what the weight is of the rig they are towing? Looks substantial. Does anyone know what Airstream model it is, and the length?
It is a custom outfitted Airstream 22' Sport (same as mine and @JimVandegriff's). Bay Area Airstream made a few of them for Tesla. I believe the rep said three were made. Since it's gutted and outfitted solely with the design studio gear, I would guess that it's quite a bit lighter than my trailer. Rough guess would be in the 2400-2800lb range. Very, very rough...
Thanks for that info. Wish I knew if Tesla has experienced the same issue you had with your factory hitch when towing your Airstream 22.
They even replaced the electric jack to save tongue weight. Oh, and they also use LED adapter on the 7-pin wiring. Anyone else have problems with those?
The 22 Sport comes with a manual tongue jack, believe it or not. I added an electric one myself to facilitate faster hitch/unhitch procedures. I also had to use the Curt LED adapter.
Oh really, I didn't know that. Our dealer must upgrade them on-site. I've gone through three adapters this summer. Granted, my luck as of late is not great, but I expected them to last more than a trip or two.
In case that you want to tow a trailer with a standard mounted hitch, your trailer’s weight will be transferred to the rear axle of your vehicle. You should use weight distributing bars so that you can come together and improve the hitch system. You can see Weight Distribution Hitch system here.
I know I'm late to this party, but as I read this thread, it seems the consensus is NOT to use a WD hitch, but use the Bosal. I am planning on towing a Condo Safari 2124 trailer.
I just re-read this thread and that is not my impression. If you are towing a trailer that weighs 50% or more of the tow vehicle you should use a WD hitch. One can even make a case for using a WD hitch on lighter weight trailers. The weight of the Alto A2124 is shown at 2,556 lbs at Alto – Lightweight Travel Trailers | Safari Condo . I assume that is dry weight. With a full water tank, kitchen stuff, food, clothes, etc., it will be several hundred pounds more and now you are likely at more than 50% or more of the weight of your Model X. A WD hitch would be advisable. But the Bosal that comes with the X is not a WD hitch. @ohmman switched to a DrawTite WD hitch and seems to be quite satisfied with it. My Alto F1743 has a dry weight of 1,753 lbs. I estimate when fully loaded it weighs no more than 2,200 lbs. I have been using the Bosal hitch for over 10,000 miles of towing in the nearly two years I have owned my trailer. I have never felt unsafe when towing including in crosswinds, though I have not been in severe (50+) crosswinds.
Found this video, thought it might be helpful to show what happens when your load is biased behind the rear axle of the trailer. Also watch out for the big finger, it will get you every time
We have been towing a trailer with similar specs (dry weight 2500lbs, GVWR 3500lbs). After ~15000 miles, without a WD hitch, we've seen no loosening of the Bosal receiver and have had no issues with towing. We keep the Bosal in 100% of the time, whether towing or not. If you need to use a WD hitch you can't use the Bosal (according to this video). Bosal Hitch Adapter Loosening
Weigh Safe has introduced a WD hitch. See link below. I used their hitch and appreciate its quality and built in scale to tow our 2020 AS Bambi 22FB. Been quite helpful in ensuring I don’t go over the tongue weight limit. https://www.google.ca/url?sa=t&rct=j&q=&esrc=s&source=web&cd=3&cad=rja&uact=8&ved=2ahUKEwiT2KLnqYbpAhXYlXIEHU9hAvIQtwIwAnoECAEQAQ&url=https://www.weigh-safe.com/product/true-tow-weight-distribution-hitch/&usg=AOvVaw3PVQVbJQyehonAvLDwRSEI What’s unique about it is their tool to calculate the right setting to distribute the weight. Today, I do it ‘manually’ with the help of Haul Gauge and place cargo around my X and Bambi to balance things out. However, it’s tedious and there is still sway I’m not dealing with. I’m interested by this product, though it does weigh 143 lbs. I’ve been reading a lot on this and I’m encouraged by the fact that from what I gather, the weight of the hitch should be added to the cargo weight of the two vehicle versus the tongue weight, on which I’m close to the limit on. I’m also encouraged by the fact that @ohmman and @JimVandegriff have been towing with a WD hitch and have not had to my knowledge related issues (suspension-wise or structural) on their X (beyond the one with the Bosal hitch, which wasn’t minor!). Anyone has thoughts on this? Thoughts on the X’s tolerance to WD with its air suspension? P.S.: I have installed a Draw Tite hitch.
This is a really neat product. @ecarfan has a Weigh Safe ball mount and has reported good success with it. The idea that you can calculate distributed tongue weight is pretty useful, especially if you're concerned about being close to the limit on your hitch. I would be interested in the dynamic loads during driving, however - an electronic companion app or something like that would be pretty neat.
Nope. No trouble at all. I'll say that my WD hitch barely has to distribute, though, so the real stress is going over bumps and uneven roads, not typical driving. I pull the bars off before driving to the campsite, and before driving up my gravel road. Still - the car is doing great!
That is good to hear. I think I will bite the bullet and drop my ball-only towing and go with this hitch. It is 143 pounds of added weight at the hitch but I will choose to believe the weight distribution will work its magic (which Weigh Safe confirmed it would). I shall report back once tested (which first requires parks and campgrounds to reopen in these parts!).
