Ok well you're good with tinkering and understanding this stuff. Didn't know it had an external antenna, sothen it should be fine. If the antenna was on the board and they coated it, that would throw the reception off.
Well, so far, so bad...
I powered the unit up on my workbench. The unit is a three wire device, +12, Gnd, and some communication line. There is a 5V regulator which is working fine. The communication line was silent as it sat on my bench. I am guessing it needs to be polled.
The communication line was idle at 12V. And there is a level converter 5V for the logic.
There is a 8Mhz osc that was flipping from about a 5V swing to about 1.75V... Seemed to be changing due to pressure on the board. But I don't know which is correct. (If a bad connection was loading it, or was unloading it...).
There is also a 13 Mhz osc/tank, but it was silent.
The osc/tank is just a two terminal device, and the component designations are Y1 and Y2... not really helpful.
I reinstalled the unit, and measured the voltage, and it is powered when in the car. I didn't drag my scope under the car, which would be the next step.
Here is the unit lifting out of the case, where you can see the antenna wire along the left and back.
And here is a view of the board after I cleaned it ("Goof-Off", acetone, denatured alcohol... just not all mixed together).
The circuit board antenna, and the wire. I also destroyed a cap when cleaning it, but it's just a power filter cap on the output of the regulator. And 220uF, 16V are about as common a leaves...
There is more I could do, but I'm busy now with lots of stuff. I'm taking the car in to replace the brand new defective cabin blower, and I'm gonna tell them to fix this under warranty, since they convinced me to play them $500 last time only to have it fail 1 year, 2 weeks later. And the old adviser told me once I paid to have these replaced, I should be good for 4-5 years. Although I doubt they will do that, or show any kind of flexibility. Add to that the fact that they make me wait another 2-3 weeks after I call before they even get me in... this service center is really crappy customer service.
Maybe I'll hack at it more in December. I'd love to get a schematic of this thing. Or a manual. Anyone have any leads on that?
